Sprayed the TBI on the dyno
Old Jun 3, 2005 | 06:48 PM
funina91ss's Avatar
Car: 91 RS
Engine: 5.3 LS
Axle/Gears: 3:23
Well I got the RS to the dyno today. First NA pull was
176hp
232ft lbs
50 shot
200 hp
306tq
75 shot
230hp
325tq
100 shot
302hp
394tq
I will post the graph when they get it up.
305 TBI small cam (stock LT1 size) 6speed moser 12 bolt 4.10's On Nittor DR. on a Dyno Jet!
I was looking for 250hp and 350 tq on the 100 shot. I let the car cool good and got the bottle temp to 1,100 on the 100 shot. I pulls real good now. (I just need to learn to shift it faster now)
Old Jun 3, 2005 | 07:53 PM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
from 75-100 you gained 72hp????
sure it wasn't a 125 shot?
and that helped you get another 125hp from the NA run?
was this real wheel? or just motor?
Old Jun 3, 2005 | 10:15 PM
funina91ss's Avatar
Car: 91 RS
Engine: 5.3 LS
Axle/Gears: 3:23
It was RWHP. I didn't let the car cool any between the NA runs up to the 75 shot. Before I ran the 100 shot I let it cool for about 45 min. and got the bottle pressure up to 1,100psi.
I am using NX kit with a NOS Plate, with NX jet settings. Jetted for 100RWHP. I also only made on NA run. It might make more power than 176 hp.
Old Jun 3, 2005 | 11:09 PM
funina91ss's Avatar
Car: 91 RS
Engine: 5.3 LS
Axle/Gears: 3:23
Old Jun 4, 2005 | 10:01 AM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
Good numbers.
If you don't mind me asking, how reasonable were their prices for the dyno pulls? I've heard it's hard to find a dyno that will let you use nitrous. I'll hopefully have my car running near the end of summer and would love to get some numbers. Btw I work in Huntington.
Old Jun 4, 2005 | 10:12 AM
funina91ss's Avatar
Car: 91 RS
Engine: 5.3 LS
Axle/Gears: 3:23
Originally posted by IROC315
Good numbers.
1 run $45
1/2 hour $65
1 hour $95
Spray as much as you like. Tony is a realy good guy too.
Old Jun 4, 2005 | 11:51 AM
CRZYTRN-92Z28's Avatar
Car: 1992 Z28
Engine: 350 L98 w/ D-1SC
Transmission: POS 700-R4
Sweet numbers. That thing is kinda lean on the bottom though.
Old Jun 4, 2005 | 02:50 PM
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
I was thinking the same thing. 16:1 AFR is scary. But it did drop after a little bit.
Old Jun 7, 2005 | 05:10 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
thats lean enough it may make more power with some more fuel!
better fix that!
Old Jun 7, 2005 | 09:25 PM
katman's Avatar
Car: 91 Z28
Engine: 468 ci
Transmission: thm 350
DON'T USE NITROUS EXPRESS SETTINGS WITH A NOS PLATE AND JETS!!! USE NOS SETTINGS!!!
Each companies jets are different. Nitrous Express jets are less than +/-1% tolerance. NOS have been known to be +/- 6% tolerance. This is why Nitrous Express makes their jets a different size so that they can't be used in any one else's systems.
Old Jun 8, 2005 | 12:09 AM
Car: 1992 Z28
Yep what he said. Look at how your making great power and then it spikes when you run out of fuel. If you give it some more bet you pick up quite a few more ponies.
Old Jun 8, 2005 | 06:36 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Nice numbers. What are the actualy jet numbers you are using?
I made quite a bit more power N/A in my car, but even jetted at 130hp, I didn't quite touch the 300hp mark. (no bottle heater, so I'm sure my bottle pressure was low)
I also seem to go lean just like you when I open it up, I have since messed around with my AE some more, I need some more dyno time to tune that out.
Old Jun 9, 2006 | 10:42 AM
funina91ss's Avatar
Car: 91 RS
Engine: 5.3 LS
Axle/Gears: 3:23
new times
Started out on Nittos and a 100 shot. I think my best with that setup was a 8.63 The tires were spinning pretty bad. So I got tired of that and put my et streets on and went a 8.32 (100 shot)
Then I put in the 150 jets and went a 8.05 1.70 60ft @ 85mph. then a 8.07,8.08,8.08.
I really wanted it to go in the 7's maybe with a little more traction and some tuning it will be there. The car ran great and I had a blast shifting the gears. I will try to get some video's up for you guys to see.
I also wanted to run a 200 shot but I didn't have any jets for a 200 shot.
Might just have to stick with the 150.
Old Jun 9, 2006 | 12:59 PM
high c's Avatar
Car: 86 iroc
Engine: yea it has one
Transmission: yea it has one of them also (im 2 for 2) :)
looks like your running a lot lean at 3500 rpm (you do make the most power when your melting **** )
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
db057
Jan 10, 2020 08:55 PM
89bird2.8
Sep 18, 2015 07:46 PM
