PLEASE help on this one, 2 wires left!
Old Jun 3, 2005 | 10:49 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
I have a WOT switch with 3 prongs. I have 2 wires to attach to it...one from the Arming switch and the other from my MSD box pink wire/red wire on the relay....
which wire go where? I think the top prong is not used.
Please help!!!!!
Old Jun 4, 2005 | 07:48 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
there should be a small picture on the other side of the switch. it will show how it works
so yes one might (most likely) not be used. I would check with a meter if you are unsure.
Old Jun 10, 2005 | 08:25 PM
vbMike's Avatar
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
Use a tester to check for continuity. Open the throttle all the way so that it is tripping the switch. Then use the tester to figure out which two posts allow the current to pass. That will be the two terminals that you will want to connect the wires to. One post will not be used. It shouldn’t matter which wire goes where after you figure out which two posts to use. Hope that makes sense.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Bert87
Aug 23, 2015 03:50 PM
