power chips which one is right for 91tpi,5spd
Car: 91z28vert,3:42posi-rear,gu6
Engine: 305TPI
Transmission: T-5,pro5.0 shifter
can anyone recomenned a good power chip to gain horsepower there are quite a few out there and only want to buy one that i know some else has had good results with,i dont have a lot of money but would spend 300.00-500.00 for a decent chip,any info would be greatly appreciated thanks, 91vert,305tpi,also car is completely stock underhood if that will help with choices,its also a 5spd
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
I think you should post this in the TPI section.
Also if I was you and your willing to spend $500 on a chip, I would take that money and use it to get some performance stuff under the hood..unless your wanting to keep it stock.
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
A chip aint going to do squat for you, your better off spending your money elsewhere, read this to give you a idea what these off the shelf chips are all about https://www.thirdgen.org/techbb2/sho...hreadid=104792
^^^ what they said. To add, you could learn a lot from reading this site and start burning your own chips for well under $500!
For future reference, power adders refer to superchargers, turbochargers and nitrous.
sailtexas186548
Aug 24, 2015 10:11 PM
