What To Do To Supercharge An L98?
Old Jul 18, 2005 | 02:07 PM
NBMIROC's Avatar
Car: 1989 IROC-Z Camaro
Engine: 5.7
What must be done to supercharge an L98? Will the motor need to be worked on? Or will the bottom end hold up? Will forged parts be needed? Compression changes? Fuel Delivery? Spark? I am looking at buying an L98 GTA or IROC in a few months and think supercharging it would be a good way to go.
Minus the cost of the supercharger itself, how much do you think it will be to properly prepare the care for a supercharger?
Thanks guy!!
PS: Don't worry, I am doing alot of searching, but hearing it first hand is always good.
Old Jul 18, 2005 | 02:13 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Welcome
Ill great ya with a nice SEARCH, honestly this Forum has one of the best searches i use on the 6 or so forums i try to stay up todate on.
First thing you need to ask yourself, is what do i want this car to do, and how much money you would like to spend.
If you build a motor for lets say 12lbs of boost, with all forged parts, and a compression of 9:1 and go with some AFR 195 Heads, then ur looking at atleast $5,000 for the engine, and another 2800-3800 for the Supercharger, Companies that make kits are Vortech and Procharger, im biased to Procharger, only becuase i like some of the technologies they put into thier headunits, plus they are 5min away from me
Old Jul 18, 2005 | 02:46 PM
CrazyHawaiian's Avatar
Car: too many ...
The L98 in my 91 Z28 has been boosting 6 psi for over 50k miles and its running great with proper maint, all stock.
Old Jul 29, 2007 | 10:58 AM
IROCU2's Avatar
Car: 1987 IROC-Z
Engine: 5.7 TPI
Transmission: 700-R4
Re: What To Do To Supercharge An L98?
So CrazyHawaiian are you saying that your car is supercharged? If so how did you go about doing it? Thanks
Old Aug 4, 2007 | 03:04 AM
1fas92's Avatar
Car: 1992 Z28
Engine: Forged LS3
Transmission: T56 stage 2 clutch
Axle/Gears: 35 spline with 3.55 gears
I DONT MEAN TO HIGHJACK YOUr THREAD, BUT HERE YOU GO....
I have a vortech sc for sale & a set of long tube headers. Check it out if your interested...
Thanks,
Robbie
1fas92
https://www.thirdgen.org/forums/engi...v1-s-trim.html
91chevyz28
Feb 10, 2022 07:58 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Tarizza
Sep 24, 2015 12:57 PM
-=Z28=-
Sep 24, 2015 10:21 AM
