turbo blow-thru sbc --- gas mileage
Old Aug 6, 2005 | 05:37 PM
91rs5.0's Avatar
Car: 91 RS (Black, T-top)
Engine: 5.0
Transmission: 5-speed
Anyone with a sbc with a blow-thru carb setup? If you drive your car on the street? How streetable is it? What kind of gas mileage do you get? I want to go this route, because its cheaper and easier than efi, but don't want to get less than 10mpg. I know this setup is also very capable of high power numbers(turbo mustangs 1200+ rwhp) I know most of you don't care for economy, but with gas prices near $3 per gallon, and I want to drive my car as much as possible, so give me your opinions.
Old Aug 7, 2005 | 01:36 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
If your going to go that route dont expect good gas mileage. I would highly recomend the carb box. My buddy tried to use the blow through carb with a supercharger and it leaned out before he could let off and poof there went his motor.
Old Aug 7, 2005 | 10:21 AM
91rs5.0's Avatar
Engine: 5.0
Well. I'm hoping at least 10mpg is attainable, if you tune the carb to run close to 14:1 at cruise speed, while off boost, I hope thats at least possible, but I wanna hear it from people that have done it.
Old Aug 7, 2005 | 10:23 AM
91rs5.0's Avatar
Engine: 5.0
Carb box? Why not a carb hat? Why would it lean out assuming he had correct jetting?
Old Aug 7, 2005 | 10:46 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
How will you know the proper jetting. I guess if you want you could but a blow through carb and hat and get it dyno tunned.
Old Aug 7, 2005 | 11:06 AM
BigL350's Avatar
As long as the carb is set up and tuned right, and you're not always in boost it won't be that bad. I had my malibu out for about a month with the blow through setup and the gas milage wasn't bad at all. I don't have any figures, but it doesn't seem any worse than when I had an n/a 357 with a 670 street avenger.
Old Aug 7, 2005 | 11:30 AM
BigL350's Avatar
A wideband O2 sensor is a necessity. If you're going to tune it yourself, you have to do your homework on carb tuning. Even if you have a good handle on carb tuning it still might be worth it to you to have your carb set up by a specialist like CSU carbs. Don't be afraid to go with a small carb too. The guys that seem to have carbs that "just work" with very few changes run smaller carbs. One guy on turbomustangs.com is running low nines-high 8's on a 650DP with downleg boosters. Running a bigger carb sometimes requires annular boosters to pull enough fuel. The booster signal is so strong on the smaller carbs that they seem to just pull the fuel that they need with downleg boosters.
Old Aug 7, 2005 | 12:01 PM
91rs5.0's Avatar
Engine: 5.0
As good as CSU is I don't think I'll need it. rotoryota from turbomustangs.com ran low 9s on a 358 sbc and the same turbo i'm using, all through an almost unmodified 650 double pumper. He's using the same carb to run 8's with a bigger turbo. www.boostdoctor.com So I think i'll be using a 650 also, because it's much easier to tune than larger carbs.
Old Aug 7, 2005 | 12:02 PM
91rs5.0's Avatar
Engine: 5.0
You beat me to it.
Old Aug 7, 2005 | 12:20 PM
BigL350's Avatar
That's exactly who I was thinking of! If I had to do it all over again I'd start with a 600 or 650. I was having trouble getting fuel out of my 750, drilled pvcr's, smaller bleeds, more jet, and I was still getting a part throttle lean spot and going lean at the top end too. It was getting me nervous so I just said screw it and sent the carb to CSU.
Old Aug 8, 2005 | 09:34 AM
browncamaroz28's Avatar
Car: 1982 Camaro Z28
Engine: electric
Transmission: powerglide
Axle/Gears: 10 bolt
anyone know about doing a blowthrough on a carter afb type carb like the edelbrock performer? i plan to run a gt40 based turbo with a 650cfm version......
Old Aug 8, 2005 | 12:18 PM
BigL350's Avatar
http://www.turbomustangs.com/forums/...threadid=22107
Old Aug 8, 2005 | 02:00 PM
Engine: electric
Axle/Gears: 10 bolt
thank you sir, thats almost more info. then i can handle.....
Old Aug 8, 2005 | 08:20 PM
blown3rdgen's Avatar
I too run a blow thru carb. Gas mileage not bad at all at idle/cruise. However I can watch the gauge drop towards E when I'm in it with the drilled pvcr and larger secondary jets.
Like these guys said- watch/search the turbo mustang site. I have learned alot from them.
Matt
Old Aug 9, 2005 | 05:07 PM
Engine: electric
Axle/Gears: 10 bolt
with blow through we have to boost reference the fuel pressure right?
Old Aug 10, 2005 | 12:43 AM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
yes
Old Aug 11, 2005 | 09:00 AM
x007's Avatar
Car: Supercharged Nitrous T/A
Engine: Motown 410SBC
Transmission: 4L80 - Compushift / Custom billet torq
Axle/Gears: 12b Moser 33/spl. /373 posi
Here is what you need
Old Aug 11, 2005 | 01:16 PM
Engine: electric
Axle/Gears: 10 bolt
i would but i am cheap as hell, plus i just bought a new edelbrock performer
Old Aug 11, 2005 | 02:50 PM
x007's Avatar
This is less costly than a new engine ...
Playing whit a carb not done for a blown trhu will cost you
a lot more !!!
Your choice
Old Aug 11, 2005 | 03:59 PM
Engine: electric
Axle/Gears: 10 bolt
it will cost me alot less to mod this one with the marine accelerator pump and solid floats then to buy that. Plus if the carter engineers could do it so can i...... www.vs57.com/carb.htm
If i wanted to spend alot of money on a fuel system i would just buy a fuel injection computer and build a custom system.
a lot more !!!
Your choice
Old Aug 12, 2005 | 08:54 AM
nightrider87's Avatar
On that carb....what is the line that runs from bowl to bowl?
Old Aug 12, 2005 | 09:16 AM
x007's Avatar
used for pressure equalization on each bowl.
Azrael91966669
25
Jun 20, 2017 04:04 AM
1986Z28OWNER
Dec 13, 2015 10:19 PM
dbrochard
Aug 30, 2015 05:56 PM
FreeSpirit
Aug 29, 2015 05:47 PM
InfinityShade
Aug 22, 2015 08:00 PM
