Combined power adders - SC/turbo & nitrous
Old Sep 1, 2005 | 09:29 AM
slickrock55's Avatar
Car: 82 Trans am
Engine: Twin turbo 350
Please post up your combo if you're using both forced induction AND nitrous on your car. A little info in getting them tuned to run smoothly together would help also.
I've got a twin turbo setup running about 14psi that runs pretty well. I'd like to get some opinions on having maybe a 100 shot of nitrous for a little extra "insurance" when there's money on the line. I have a limited knowledge of nitrous setups, i know having a WOT switch and a window switch are important etc, but of course i would do all the homework before venturing down this path.
Old Sep 1, 2005 | 02:47 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Re: Combined power adders - SC/turbo & nitrous
Then hit the books.
Old Sep 1, 2005 | 03:27 PM
Car: 82 Trans am
Did a
didnt find anything about COMBINING forced induction and nitrous, which is what my question was about. I'm not asking about basic nitrous stuff.
Old Sep 1, 2005 | 10:33 PM
79vette's Avatar
Car: 1979 Corvette
Engine: 355, TFS heads, comp 270H cam, 10.5 comp.
Transmission: 700r4/ 3:55 posi/ 2500 stall
You got turbos running at 14 psi on a small block chevy and you still need insurance? Man what the heck do you plan on taking on? Why not just add more boost?
Sorry I can't help much on your question, but I did find this a little amusing.
Old Sep 1, 2005 | 10:38 PM
79vette's Avatar
Car: 1979 Corvette
With any forced induction system though, the name of the game in surviving the pressure is keeping detonation down. Your gonna have to add more fuel while you dump the NO2 into the motor and possibly retard the timing while you do the shot. You just got to figure out what you can get away with with out the deadly pinging. Nitrous has the real tendency be extra detonation prone, worse than turbo boost, because of the sudden burst of compressed air into the chamber. Most turbo guys using NO2, use it to help spool up the turbo faster.
Old Sep 2, 2005 | 07:39 AM
Car: 82 Trans am
I did a little more searching elsewhere and found a little info, and the more i think about it, the more i believe it may be better just to crank up boost a little bit. The only time that nitrous would be the only way to help is by using something like a 50 shot down low to help from the area just off idle to the boost threshold.
Old Sep 3, 2005 | 04:27 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
What about with a Supercharger?
I was thinking about adding a dry 75 shot to an ATI setup with minimal boost 6-8psi.
Old Sep 3, 2005 | 04:59 PM
79vette's Avatar
Car: 1979 Corvette
Same principles apply, you need to know what you can get away with without detonation. Why not get a more agressive pully on the S/C if you wanna up the power?
Old Sep 3, 2005 | 05:00 PM
Jack G Jr's Avatar
You can try looking over at KennedyDynoTune.com.They have a article on dual poweradders even a customer with a 4th gen running both and still drive it everyday
Old Sep 3, 2005 | 05:06 PM
Car: '89 GTA
I do have the other pulleys as well, but was thinking the nitrous could add to the intercooling effect.
1986Z28OWNER
Dec 13, 2015 10:19 PM
Reborn756
Sep 4, 2015 03:42 AM
Slush92RS
Sep 2, 2015 08:56 PM
sailtexas186548
Aug 24, 2015 10:11 PM
