building a nitrous motor
Old Sep 4, 2005 | 09:19 PM
92camarors5spd's Avatar
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
Axle/Gears: strange 12 bolt 3.73's
ok so im going to build a 355. plan on putting eagle esp forged hbeam rods, and esp 4340 forged steel crank. and a set of forged pistions. and the gm fast burn heads. with accell dfi system. now i want to build a daily driver with about 400hp at the wheels. and i want 500hp at the wheels when its time to take it to the track. now how do i go about building a motor to withstand nitrous. and also compression ratio. is a nitrous cam street friendly? so if you all have any tips that would be great. are there any kind of special pistons/rings for nitrous? i want to be able to run a 2 stage set up maybe 50 off the line and 100 once ive hooked up. i dont know to much about nitrous other than its an awesome way to keep streetablity.
thanks
Old Sep 5, 2005 | 10:45 PM
WhiteHawk's Avatar
Car: 1991 Firebird
Engine: 350,Dart Heads,Weiand In,Roller Cam
Transmission: 2400-Stall, 700R4 w/ Kit
Axle/Gears: 4th Gen 3.42 disc (I wish)
You are on the right track with the forged everything in your setup. The compression should stay below 9:1. I believe you're supposed to increase the ring gaps. Why are you only running a 100 hp shot with this beefy engine you are building? Most people agree you can go a 125 shot on stockers. As for the cam I would call up crane cams or comp and ask the techs what you need and they will get you part numbers.
You should also get a window switch (RPM activated switch) with your 5 speed tranny.
Old Sep 5, 2005 | 11:49 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
running larger rings is a MUST for larger shots. you should b able to get that horse power range at the 9.5 comp. i am running 11.1 to 1 compression and spraying a 350shot . and have a friend speaying 300 on a 13.5 to 1 stock bolck 400 . at a 100 shot you really dont need to do much , a step colder plugs that are gaped to 30 r a good idea. get a cam with 110 to 115 lsa and they do work fine on the street. a window switch is a good idea with a stick , if it bogs it will shut the nitrous off. safer on motors that way.
italiano67
Dec 11, 2016 09:21 AM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
69 Six Pack
Oct 5, 2015 07:51 PM
tricky1
Aug 23, 2015 01:17 PM
