Diesel turbo help
Old Sep 19, 2005 | 10:48 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
Diesel turbo help
Hey guys I have recently come across a Garret turbo from a 7.3L Ford diesel truck. I have a few specs but not certain to what it all means in the big picture, but i also wanna know what the name of this turbo is (T66, T60?) Can you tell me what the name of this turbo is and if its a decent single turbo for a 356 w/ a vortec stealth ram
turbo specs.
Hot side
70mm inlet
72mm~ outlet
A/R .84
Cold side
67mm inlet
64-65mm outlet
A/R 1.00
Can anyone give me a little background on this turbo and what its best used for (ex high hp, low rpm peak tq etc.) I am looking to buy this core soon if it seems to be an ok turbo for a good single turbo set-up.
thank you
Jason
Old Sep 20, 2005 | 08:58 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
There is a guy on this board that has a junk yard set up using one of those turbos. Its a white z. Not to be an *** but just scrole throught the poweradder page. You should be able to find it. Also you might get some more info from www.turbomustangs.com.
Old Sep 23, 2005 | 08:55 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
great site but i still cant find the name of this turbo or really any info...help
Old Sep 24, 2005 | 08:16 PM
NEEDforSPEED's Avatar
jason its a "garrett tp38"
Old Sep 24, 2005 | 11:31 PM
83 Crossfire TA's Avatar
It’s a garret tp38 or gtp38, depending on what it actually came off of. Not sure what you really want to know, flow wise it’s probably similar to something like a T60 or so and is a bit of a hassle to use because if its specialized oil inlet and outlet on the same flange rather then one on top and the other on the bottom.
Old Sep 25, 2005 | 09:11 AM
FlamedROC's Avatar
Car: 1989 IROC-Z
OK cool thanks guys. Its actually came off of a 2000 7.3L diesel powerstroke ford F450.
I guess what I would like to know is if it is a turbo worth using on a single turbo project on a 356? Also what Im looking for but cant find are compressor maps for this turbo.
Crossfire--thanks for that info on the oil system I wasnt aware of that. I wasnt the one that pulled it off so I didnt know how the oil system was hooked up. I've also come to notice that it doesnt seem have the ability to be clocked so I may have a rough time finding a proper location for it.
NeedforSpeed---Dude I havent seen you for a long time...I finally have come to the dark side...Send me an e-mail or PM telling me about the latest on your camaro!
Old Sep 25, 2005 | 11:42 AM
FlamedROC's Avatar
Car: 1989 IROC-Z
heres a few pics of the turbo
Old Sep 25, 2005 | 08:01 PM
Mike-91 Formula 350's Avatar
I've read they are good for around 500 FWHP
Old Sep 29, 2005 | 10:42 AM
any updates?
Old Sep 29, 2005 | 06:40 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
No But Im pretty sure that the turbo will be mounted under the front of the car in front of the passenger wheel...I need more info on this turbo before I go any further.
anyone with .02 cents on the subject please chime in.
Jason
Old Sep 29, 2005 | 07:14 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Sorry off topic but you work at the goodyear off of 35w dont you.
Old Oct 22, 2005 | 08:50 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
grover I couldnt find the guy that you said had this turbo can u help me find his post?
Is this a worthy turbo for a 356 looking to get 500-550 rwhp? Should I go bigger?
I am not liking the idea of not being able to clock this turbo. there are not many ways this turbo will fit under my hood. What are some alteritive turbos I could use to see my power potential?
Goals I have for the car
single turbo set-up
500-550 rwhp
low 11's to high 10's in the 1/4
93 octane
intercooled or meth. injection
some street driving
Jason
Old Oct 22, 2005 | 09:31 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Whats your budget? I wouldnt really recomend using that turbo any ways. I think it would be to much head ach
Old Nov 6, 2005 | 04:56 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
Yea I for a different one already! Hopefully someone will buy this one so I can get a a different one.
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
school boy
Oct 22, 2015 11:47 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
