91 305 vorecth supercharger breaking up above 3000rpms???
Old Sep 29, 2005 | 08:40 AM
DGROBELS's Avatar
Car: 1991 FORMULA
Hi ive had the s trim vortech on the car for about 3 years now and now out of no where the car is breaking up above 3000rpms, we are thikning the boost timing controller box has gone bad???
Old Sep 29, 2005 | 09:49 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
I had that problem before with a mustang and it turned out to be a fuel problem.
Old Sep 29, 2005 | 10:12 AM
DGROBELS's Avatar
Car: 1991 FORMULA
could my fmu gone bad? i need help car is running liek utter **** and i can even floor it?
Old Sep 29, 2005 | 11:37 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Put a fuel pressure gauge on it. Not exactly sure how much fuel pressure you should have but it should be like 70 to 90 psi. under boost. Did the vacuume come undone between the fmu and the intake?
Old Sep 29, 2005 | 12:26 PM
DGROBELS's Avatar
Car: 1991 FORMULA
we did that and it stayed at 40-50lbs so thats way off right, im gonna check the vaccum to the fmu
Old Sep 29, 2005 | 07:13 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
That sounds really low. Cause stock pressure is like 40lbs. How much boost are you running?
Old Sep 29, 2005 | 08:17 PM
DGROBELS's Avatar
Car: 1991 FORMULA
I dont have a gauge on it but when I firt put it on i put on different size pullies so if you want i can loook tomorrow and see what size pully ihave on it, at this point i never kept my foot in it cause it started stuttering/ breaking up really bad so, Im gonna trust your judgment and see if the fmu is messed up thats gotta be it??? new plugs wires distributor and still the same thing......
Old Sep 29, 2005 | 08:27 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
I would belive so. Check your spark plug gap. You might be blowing out your spark. But I think its fuel. The pressure seams way to low. I had this same problem with a mustang and we had 60 psi fuel pressure and it still did the same thing. What kind of fuel pump / pumps are you running.
Old Sep 29, 2005 | 08:35 PM
DGROBELS's Avatar
Car: 1991 FORMULA
this car is bone stock with just the s trim and flowmaster cat back exhaust, it never did this before, it has the stock intank pump and the pump vortech sends with tke kit....
Old Sep 29, 2005 | 11:56 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
my car was breaking up starting around 3000-3500 (part and full throttle) when I first put the turbos on it. turns out it was the knock sensor (for the most part). It was taking out like 13 degrees of timing and it wasn't even knocking. I disabled the knock sensor and it still started to break up at 4500, it was a little rich. I leaned it out to 12.5:1 air/fuel ratio. and it runs great. I'm taking out on average 2.5 degrees of timing per pound of boost to keep it safe at 8psi. On the Vortech website it says the FMU with the kit makes an 11.5:1 AFR. I'd leave it there probably.
Old Sep 30, 2005 | 12:28 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Check with vortec but I am almost 100% sure you dont have enough fuel pressure. This may be a dumb question but when was the last time you changed your fuel filter?
Old Sep 30, 2005 | 10:02 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Oh shoot I forgot. Were you checking fuel pressure at idle or were you driving with a fuel pressure gauge on the car. Cause you need to drive it and when it falls on its face whats the fuel pressure at?
Old Sep 30, 2005 | 06:45 PM
DGROBELS's Avatar
Car: 1991 FORMULA
i had my riend hold it while driving and i didnt see it go past 50 at all...i havent changed the fuelter in a long time!!! could tha really be it?
Old Sep 30, 2005 | 08:58 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
yeah it could be. I recomend changing your fuel filter like every 20000 miles. But I am sure the fuel pressure is to low. Are both fuel pumps working?
InfinityShade
Feb 21, 2016 01:29 PM
toronto formula
Nov 10, 2015 06:17 AM
bdads
Aug 24, 2015 06:01 PM
anesthes
Aug 24, 2015 08:32 AM
PestilenceIV
Aug 20, 2015 03:32 PM
