Boost reference points?
Old Oct 2, 2005 | 06:03 PM
Raven90IROC's Avatar
Car: 1990 Camaro IROC-T
Engine: L98 Turbo (GT40)
Transmission: THO400
Axle/Gears: Forged axles, 3.23 rear
Where else can I get a boost reference off on the plenum. So far I have my gauge, wastegate andBoV all T-ed off the port near my MAP sensor. Now I need to add my FMU and would like to put it on its own port.
Where else can I use?
Old Oct 3, 2005 | 07:46 PM
Anyone?
Old Oct 3, 2005 | 08:09 PM
The_Raven's Avatar
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
You could always drill and tap a new fitting.
BTW I haven't forgotten about you, I just have to look through the boxes I have for the item you seek.
Old Oct 12, 2005 | 06:51 PM
high c's Avatar
Car: 86 iroc
Engine: yea it has one
Transmission: yea it has one of them also (im 2 for 2) :)
just tap into the vac line going to your stock fuel press. reg
Old Oct 12, 2005 | 07:16 PM
89JYturbo's Avatar
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
Yes, just use T fittings installed in the existing vacuum lines. The FMU needs only a very small intake manifold pressure source, so you don't need a dedicated port (just make sure all the connections are solid- I use zip ties to make sure the vac hoses don't come apart when under boost- if the hose comes off the FMU while you are supercharged, you may go lean and end up walking home). Most FMU's come with a restrictor to install in the manifold pressure refernce hose.
seiplentz
Aug 19, 2019 06:02 PM
Elephantismo
Feb 13, 2019 12:51 AM
customblackbird
Oct 1, 2015 04:30 PM
Hill1513
Sep 19, 2015 04:15 PM
Doobie52
Sep 11, 2015 06:19 PM
