It has finally arrived...
Old Sep 29, 2005 | 04:24 PM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
The kit is part# 05151-15nos. I hear alot of different opinions on whether I should go with 100 shot or 150. The short block has 225,000 miles on it but it doesn't smoke and runs great. It's a 305 by the way. What do you yall think?
Old Sep 29, 2005 | 09:26 PM
DGROBELS's Avatar
Car: 1991 FORMULA
225,000 go with the 100 shot, its gonna blow up either way sooner or later..but sooner than later....lol have fun with it
Old Sep 29, 2005 | 09:57 PM
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
I say put the garden hose to it its already on the way out might as well see how much abuse you can put to it
Old Oct 1, 2005 | 05:40 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
If you were trying to make it last I wouldn't even put a 100 shot on it
Old Oct 1, 2005 | 05:51 PM
pwdbychevy's Avatar
Poor 305, I'm gonna miss it
Old Oct 5, 2005 | 09:38 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
Go for 300
who wants a 305 the sooner the better
j/k
Old Oct 6, 2005 | 05:59 PM
caribbean 85's Avatar
Car: 1985 Berlinetta (drag only)
Engine: 383ci chevy
Transmission: TH-350 T-brake
Axle/Gears: 9 inch Ford & 4.56 gears
A by the way ?? for pwdbychevy
were the lexan look covers for your headlamps fabbed or are they available as is ??
Old Oct 6, 2005 | 07:08 PM
pwdbychevy's Avatar
I made the covers from 1/4" plexiglas.
Old Oct 7, 2005 | 02:29 AM
Car: 89 Formula
stupid Q what size bottle is that it looks HUGE
Old Oct 7, 2005 | 03:03 AM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Run 150 ...
4in bore motor should be on the way tho...
Old Oct 7, 2005 | 03:04 AM
Engine: 350 tpi
Beaut of a car wuts yur cardomain url?
Old Oct 7, 2005 | 05:36 AM
pwdbychevy's Avatar
It's a 15lb bottle. It fits quite nicely above the battery in the spare tire well.
Old Oct 7, 2005 | 05:37 AM
pwdbychevy's Avatar
It's http://www.cardomain.com/ride/781816
Old Oct 7, 2005 | 11:45 AM
Car: 89 Formula
Yeah it looked wayyyy to big to be a 10 thanks
Old Oct 7, 2005 | 11:59 AM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
NAAAAAAAAAAAAAAAAWWWWWWWWWSSSSSS
why didnt you get "2.. of the big ones".. ?
Old Oct 7, 2005 | 12:20 PM
pwdbychevy's Avatar
no way dude, no where to put it "incognito"
Old Oct 7, 2005 | 01:48 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
yeah it was a joke
Old Oct 8, 2005 | 02:38 AM
Engine: 350 tpi
The headlight covers look very good what did you mount them to?Do they clip on or are they bolted?
Sorry i guess i should have pmed this but i am curious.... I hope i havent stolen this thread...
Old Oct 8, 2005 | 07:37 AM
pwdbychevy's Avatar
I sent you a PM on the covers.
Old Oct 9, 2005 | 06:26 PM
pwdbychevy's Avatar
I just finished mounting the bottle. I didn't think it was going to fit but it fit like it was meant to be there.
Old Oct 10, 2005 | 12:00 AM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
Ummmm isn't it kind of dangerous to mount flammable gas right above a battery LOL, I would have thought for concealing and safety you could have put it into the rear well and shut the privacy cover if you have one LOL
Old Oct 10, 2005 | 12:30 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Do you go to the track at all? How do you get away mounting your battery like that?
Old Oct 10, 2005 | 05:38 AM
pwdbychevy's Avatar
N2O by itself is not flammable. All it does is make the air/fuel mixture much denser by adding oxygen and dramatically cools it by adding nitrogen hence the N2O.
Old Oct 10, 2005 | 05:40 AM
pwdbychevy's Avatar
The battery is held down with a battery hold down kit which includes the battery tray. Trust me, everything is solidly mounted.
Old Oct 10, 2005 | 08:35 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
No I mean I got bitched at for it not being in a sealed box and have a switch to cut it off on the back of the car.
Old Oct 10, 2005 | 01:58 PM
pwdbychevy's Avatar
oh i see, do you race for money? i go down to the bradenton track and they don't mess with anyone. i guess it depends on who's running the show.
Old Oct 10, 2005 | 02:28 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
oh the track I go to they are kind of **** about that stuff. I guess they are worried about the liability.
Old Oct 11, 2005 | 01:39 AM
83 Crossfire TA's Avatar
2 thoughts there: Mounted like that, not in a sealed box, probably without an outside cutoff switch will not pass tech at most tracks, I don’t see a blowdown tube either, and second, even if you get away with it, if you ever enter an event and win (say bracket race or whatever), if someone catches wind of it and bitches to whoever is running the race they’ll strip you of your win for not having a legal car…
Old Oct 11, 2005 | 05:40 AM
pwdbychevy's Avatar
I haven't installed the blow down tube yet. What I'm thinking about doing is separating the bottle from the battery with a section of plywood or plexiglass. There's enough room between them to slide one in and bolt it down. That should seal off the battery. As far as a remote cutoff I haven't figured that one out yet.
Old Oct 11, 2005 | 08:12 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
I think the rule states for our cars is you have to have a sealed battery box. And that doesnt mean the cheap plastic ones.
Old Oct 11, 2005 | 09:53 AM
The moroso plastic ones are OK, it really just has to be sealed and vented outside. Wood isn’t a valid firewall as per the rules, steel or aluminum…
Really, I'm not sure that I see the point with an optima or one of the newer, compact dry cells, but those are the rules. I'm pretty sure that there was talk of changing them with batteries that don't leak/vent, but I don't think that it ever happened
Hopefully you don’t have the bottle filled yet, need to install the fitting for the tube before it’s filled.
I’ve got my NX 15# bottle mounted in the same place, but instead I made a saddle to hold the bottom of the bottle all the way at the back/bottom of the well, and then I modified one of the straps to attach to the spare tire bracket… I’m using some braded line as a blow down…
Old Oct 11, 2005 | 11:02 AM
pwdbychevy's Avatar
Do you have any pics of your setup?
Old Oct 13, 2005 | 02:11 AM
Unfortunatly, not in the 3rd gen. I had it setup similarly but not as nicely in my 4th gen prior to this and have pictures of that, but that won't help much since that space actually has a different shape and supports on a 4th gen.
Rocket-Doc
Nov 14, 2015 02:08 PM
Antips16
Oct 30, 2015 06:42 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
