Compression with supercharger
Car: 82 trans am,Project
Engine: lt1
Transmission: 4l60e
Axle/Gears: 3,27
I have a 350 tpi l98 engine with flathead hypereuctic piston and 64 cc iron heads..Can I use a supercharger with these pistons and heads?
Engine: lt1
Transmission: 4l60e
Axle/Gears: 3,27
the procharger kit comes with a intercooler...someone that have tryed out this kit with ca 10. in comp.??
Thanks..
Thanks..
Engine: lt1
Transmission: 4l60e
Axle/Gears: 3,27
hello guys....AC how much psi did you run with on your stock l98 engine?what type of cam would be a good one?
thanks
thanks
Car: Used to drive a camaro
TPIdude, I ran an 8lb pulley with an intercooled setup. Without an intercooler I woudln't go above 5-6 psi before worrying about detonation. As far as cams I don't know, my new engines cam is custom ground for that engine and my exact setup.
My cars specs are:
P1SC w/ 14# pulley
Single intercooler
4 bolt balanced 383
Eagle 4340 stroker crank
-16cc pistons
Hbeam rods
Dart Iron Eagle 215's (72cc combustion chambers)
Harland Sharp 1.5 RR's
Custom ground Comp Cam (int lift:.520 / exh lift:.540
duration @ .050 int 236 exh 248 LSA 113
Tremek tk600
SPEC stage 3+ clutch
Alum flywheel
TPIS Bigmouth Intake
SLP siamesed runners
Holley 58mm TB
(looking at Racetronix 60# injectors)
Running tunercat and $58 code
My cars specs are:
P1SC w/ 14# pulley
Single intercooler
4 bolt balanced 383
-16cc pistons
Hbeam rods
Tremek tk600
Alum flywheel
Holley 58mm TB
Don't know...haven't turned it over yet (brand new). Were hoping for 710-760 at the crank with a good tune. This is the first time I've worked with the cyclone/typhoon code so it'll be interesting.
WhteRbt
Sep 21, 2015 09:48 AM
you sure have a great engine with a setup like this...how much hp?
