All I gotta do is put it together now...lots of pics
Old Oct 4, 2005 | 12:32 AM
Project's Avatar
Car: 85 Camaro Z28
Transmission: 700-R4
Mwhahah :nuts:
In Feb I had a little accident, my hood pins sheered and my cowl busted into my windshield at a high rate of speed, buckled the fenders and warped the brackets.
I decided I would save my money and get rid of the EFI crap, I never did get it tuned 100% even after a top fuel dragster spent a day with it on the laptop.
I'm keeping the supercharger...hopefully after getting it together this month I'll be in the low low 11's.....I was getting 9mpg on the highway with fuel injection with 93 octane, I'm terrified to think what this 750 annular blow through is going to do...I really don't know if I will have enough vacuum to run brakes on the street :nuts:
That is without the 2in spacer I have to get the hat straight...dang...my credit card bills are scary...
Already had AFR 190's and good internals...
Demon 750 Annular Blow Through
Extreme Velocity Hat
MSD 85551 Pro Billet Dist
MSD 6AL Boost Master
Aeromotive 13204 Boost referenced Fuel regulator
Edelbrock RPM Air Gap
Old Oct 4, 2005 | 10:37 PM
nightrider87's Avatar
where'd you get your hat?
i'm trying to find the cheapest place for them now. did you get the O ring version?
Old Oct 4, 2005 | 11:00 PM
Project's Avatar
Car: 85 Camaro Z28
extremevelocity.com
I paid $208 w/ shipping for o-ringed.
it has a great design!
Old Oct 4, 2005 | 11:35 PM
What size cowl are you going to need to clear your intake,carb and that hat?
I'm sure it won't fit under a stock hood, which is what i'm running at the moment
Old Oct 5, 2005 | 08:46 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Turbonetics had their cast alum hats for about $80, IIRC. The design is a bit flatter, for better hood clearance. I haven't seen numbers on how flow differs. I'm running it under the stock Camaro hood, on top of an Accel Pro-ram manifold and 4 barrel throttlebody.
Old Oct 5, 2005 | 01:09 PM
Project's Avatar
Car: 85 Camaro Z28
I am not going to have any problems, I think my cowl is 5"
Old Oct 5, 2005 | 04:32 PM
do you need a cowl that big to clear it?
And is there a particularly good reason for going with the EV hat? iSkulte is running a cheaper version and getting good results...
Old Oct 5, 2005 | 05:06 PM
GodSpeedGTA's Avatar
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
How much for that super ram...base manifold, runners and plenum?
Old Oct 5, 2005 | 11:59 PM
Project's Avatar
Car: 85 Camaro Z28
I have a friend with a turbo blowthrough mustang running 18psi...going from a cheap bonnet to a extreme netted 66ftlbs and 57hp.....gains were up from 4psi...
Old Oct 6, 2005 | 01:21 AM
83 Crossfire TA's Avatar
Any pics of that setup? My Vic jr conversion just took an interesting turn and I may be using a 4bbl TB also...
Old Oct 6, 2005 | 02:08 AM
I can only find the one in their pricelist. Its part number 10351. the other part number appears to not be in the catalog.
Attached Thumbnails All I gotta do is put it together now...lots of pics-turbonetics-carb-hats.jpg
Old Oct 6, 2005 | 07:27 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
It's the one on the right - 10351 3" side entry. I welded the BOV right onto the bonnet as well. Maybe next time I go dynoing I can borrow an extreme one to compare with.
Project - If I understand correctly, it started making a difference above 4 psi? What were the before & after hp numbers, and was that the only change, or did they fine tune air:fuel, timing, etc as well?
Old Oct 6, 2005 | 12:40 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
How much for the super ram????
Old Oct 6, 2005 | 01:45 PM
Well, for one thing, blow through tuning and power increases are significantly different then FI, I'm betting a lot of the power increase in that example was a change in tuning or at least more consistent flow making tuing better across the board.
Old Oct 6, 2005 | 02:26 PM
so i could venture a guess and say that an EV carb hat makes sense when you're carburated but is less important when you're running fuel injection.
if only for ditribution of the air above the thorttle body...
Old Oct 6, 2005 | 06:46 PM
That's what I would guess... of course, it's only a guess without real dyno runs.
Old Oct 7, 2005 | 10:54 AM
Damon's Avatar
I'd agree with 83 Crossfire, also without direct personal experience with that product. Carbs HATE tight spaces above them. They like a lot of open room where air can straighten out and go into the venturis without turbulence. It can make a "night and day" difference in some situations.
Old Oct 8, 2005 | 07:07 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
We've used 4 different mfg's carb bonnets on my buddy's turbo / carb mustang.
The extreme velocity bonnet made over 30 more rwhp than the 2nd closest bonnet!
Keep that bonnet if possible!!
Old Oct 8, 2005 | 08:35 PM
Project's Avatar
Car: 85 Camaro Z28
I'm not at all suprised, I saw it first hand. The ONLY thing different was the bonnet did not clear the carb sitting forward, so they had to reposition the hat and tubing.
It really is a superior design, all the turbo mustang guys talk like it is the ONLY way to go
Superram is not for sale right now, it will most likely come up for sale on the board mid November.
BADNBLK
Nov 16, 2016 09:12 AM
aaron7
Aug 17, 2016 06:02 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
1985chevydude
Aug 20, 2015 12:29 AM
cstrobel65
Aug 15, 2015 10:19 AM
