will this nitrous set up work?
Old Oct 22, 2005 | 05:51 PM
sauer_power's Avatar
Car: 82 Firebird SE
I friend of mine has a nitrous bottle he is giving me and the line to run up under the hood. We were thinking of buying a fogger nozzle and putting it in front of the throttle body and running it that way. Anyone got any ideas of how well this would work if it will work and what kind of gain I would see from this?
Old Oct 23, 2005 | 08:33 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Gm High Performance did this about a year ago, on a stelth ramed IROCZ. They blew apart the stock air ducting and had to make a peice out of pipe. Similer to the Power Ring for 4th ge ls1's. They also had a backfire that killed the maf. It is definatly doable, just becareful like always with N2O. I can get the issue # for you if interested.
You will probably want to run a fuel soet up as well, going dry will really limit you.
Old Oct 24, 2005 | 12:39 PM
TexasLT1's Avatar
Car: '92 RS
Re: will this nitrous set up work?
yes, its called a single nozzle system. look through jegs or summit or any performance parts catalog for that matter and you'll see plenty of them. about 5 minutes of research would give you all the answers you want.
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
TheExaminer
Aug 26, 2015 04:59 PM
hectre13
Aug 26, 2015 08:17 AM
