Safest way to run N2O with a stick?
Old Oct 27, 2005 | 06:17 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
What is a good way to set up N2O if you are running it with a maunual tranny?
Window switch, monentary switch that you can release during shifts?
What?
Old Oct 27, 2005 | 08:29 AM
FORMULA355TPI's Avatar
Car: 88 FORMULA / 88 IROC
Engine: 355 / 355
Transmission: T5 / TH400
Axle/Gears: 10 Bolt-3.73 / 9"-3.90
I run a microswitch on the throttle, never had a problem with it coming on and off with shifts.
Old Oct 27, 2005 | 08:57 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Can't you just run a button that needs to be pressed by your right hand, so that when you shift there is no way you can have you hand on the button too?
Kinda like a fail save. Totally 100% imposible to have the N2O on while shifting. At least that is what I am going to do, but my N2O is more for a bit of fun around some back roads not really for the track.
For the track you need a more consistant method.
Old Oct 27, 2005 | 09:20 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Both ways would work, but the micro switch on the TB or gas pedal is more consistant. A window switch is also a good idea if you ever miss a shift.
Old Oct 27, 2005 | 09:42 AM
Engine: LS3
Can you give me a quick rundown on what a window switch is exactly? Thanks.
Old Oct 27, 2005 | 10:08 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
besides the Wide Open Throttle Switch... the "window switch" would only come on at 3000 RPM and shut off @ 5500 RPM (before the Rev Limiter kicks in ) so your nos is only on when Wide Open and within that RPM Range...
Window is adjustable.
Rafael
Old Oct 27, 2005 | 12:02 PM
Engine: LS3
OK, good thats what I thought. Thanks for the clear up ^^^^. I am gonna run the buttin just cuz the car, in my case, is more of a toy than a race car. But if i was racing I wold def run a window switch.
Fronzizzle
Mar 18, 2019 08:29 PM
camaro71633
Sep 1, 2015 10:24 AM
Bryan F
Aug 18, 2015 02:28 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
Leggman1
Aug 6, 2015 04:15 AM
