Vacuum operated accessories under boost?
Old Nov 29, 2005 | 05:17 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Can someone explain to me how vacuum operated accessories such as a distibutor still work well under boost?
Old Nov 29, 2005 | 05:23 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You don't want vacuum advance under boost, any more than you'd want it at WOT in a NA car. In fact, you probably want the timing retarded. Before electronic boost-retard boxes came out, you could get boost-retard/vacuum advance diaphragms.
Old Nov 29, 2005 | 05:30 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
So can I still run a vacuum advance distributor? With a BTM? Or get a mechanical one?
Old Nov 29, 2005 | 05:37 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I don't even know if you can still get mechanical boost retard cans, an electronic one would probably be better anyway.
Old Nov 29, 2005 | 06:57 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
so would I just disconnect the vac hose and use a btm?
Old Nov 29, 2005 | 07:04 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You'd still have a vacuum advance can for part throttle advance, but under boost the BTM would be retarding the timing.
Old Nov 30, 2005 | 05:30 AM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
I see. Im planning on running water/alky inj. I need to do some more research though. I would think that I wouldnt need a BTM if I did that. Thanks for the help.
$750 L98
Feb 1, 2025 02:25 PM
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Dragonsys
Sep 25, 2015 03:51 PM
