what turbo for rear mount DIY setup?
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
i was wondering what turbo would be decently efficient and support decent power on a rear mount (sts style) setup for a IROC with a TPI 350 with around 8.5: compression (probably around 8-10lbs of boost)
Arizona Turbo sells a t04B for $280, and the t04E-trim for 400, both brand new, would either of these be one to consider???
(P.S. the cam would be very mild, and heads would be sort of mild also, 170 or 180cc iron most likely)
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if you're only pushing less then 10lbs, then you DONT want a low compression motor...
you'd want a higher compression, good NA motor with a mild cam..
as for the turbo itself.... ehh, id use whatever i could find cheap.. lol.
Car: 91 camaro rs
so would i be able to run 8-10lbs of boost on a stock compression L98 (9.5:1 right?) without an intercooler(because of it being located so far away from the engine) on 93 octane???
and the cheap t04B would be alright?,
i was told it supports 300-550horse.
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
IIRC, the L98 had 9.3:1 SCR. You could safely run 8-10psi on a stock L98 if your tune is good.
You need a lot more info than TO4B or TO4E. DO you have a link to the turbocharger(s) in question?
Terrell351
Jun 13, 2021 01:13 PM
Eric-86sc
Apr 3, 2016 03:52 PM
