Best fuel injection for turbo
Car: 1986 Firebird
Engine: LG4 305
So MAF can't handle the airflow, and MAP is really picky about changes to the system. Is there a good "off the shelf" fuel injection system that can adapt to changes and lots of airflow from a turbo?
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
UMM kind of broad question...But Yes there are plenty of choices.. Almost all aftermarket ones are MAP based>>>But with boost you run a 2 or 3 bar map sensor... then have the fuel map add fuel based on the pressure/boost your building..
I have a fast system, 3bar map sensor with wideband O2.. takes most of the guesswork out... Other systems are DFI gen 7, electromotive TEC3, Big Stuff 3 , motec, etc etc.. whichis the best...who really knows.. all of the higher level systems like I posted above would be fine.. However your better off to stay with the newer versions... as in dont go buy a DFI gen 5 and expect it to solve all you tuning woes.. If you have the means get the WB02 option... Unless your a tuning genious youll be glad you spent the $$$$ up front for it..
Car: 1986 Firebird
Engine: LG4 305
Is there a way I can keep my TPI plenum, runners, etc, and just change out the computer? I'm looking for something like wideband O2 that I don't have to program all the tables with a laptop. I'm looking for a efi system that can learn on its own.
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
EFI is no different than carbs. You need to learn about them to make them work right. There is no complete "self learning" ECM. The stock GM ECM is "self learning", that is what the BLMs and INTs are indicating.
Car: 1986 Firebird
Engine: LG4 305
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
I think the acell dfi has it. I dont have a turbo but I am using a dyno jet wide band o2 kit with a stock gm ecm to tune my car.
There are so many choices out there, hard to say one is the best because not everyone has the same setup. I think the best one for you would be the one that has all the features you need and fits within your price range. Some of these aftermarket ECM's have alot more features than others. So like most things you're gonna have to do some research and see whats out there and what you need.
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
Re: Best fuel injection for turbo
The stock MAF does work with boost. I've blown through mine for quite some time now. It's not a race car, just a nice driver (it drives very near to stock, except for the surge when boost comes in!).
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
I think an fmu is a bad idea. Imo it comes on to late and then it adds to much fuel. Eveyone I have ever talked to said those things are junk.
Thats because they didn't buy a real one like a Cartech or Vortech SFMU. They are the only ones I know of that have an onset adjustment so you can richen up the fuel mixture before boost comes (if you want to). Those cheap fixed rate FMU's you buy off eBay will give the problems you stated.
They do work, and can work very well.
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
They all work (there’s only 2 different designs out there that I know of, the rest of the differences between FMU’s is cosmetic), its just up to your ability to tune for conditions and equipment.
As far as this thread goes, it’s largely up to your creativity and resources. Look at BBS’s setup, he just used a fuel solenoid and fogger from an N2O setup that opened when he reached a set boost level. It’s sort of a brute force approach, but it did work, and worked well.
Engine: 3xx ci tubo
I messed with a 730 ECM with AUJP code (stock 1992 TPI Camaro) and 42#/hr injectors in my car when I did my first boost app.
What I found was that the 730 ECM with AUJP code (1-bar) MAP, the ECM would run the engine lean when not is PE (power enrich) mode but the engine was under boost.
I would like to hear stories about anyone pulling a long hill with a stock ECM that is non-boost at about 40% throttle and about 6psi of boost.
An FMU is fine, just tune the ECM VE tables for use with the FMU. 89JYTurbo is running MAF from the sounds of it. And it is maxed out in terms of airflow. Basically, the ECM is blind to how much fuel to add, the FMU adds the extra fuel. The FMU is actually better with a stock non-boost ECM than installing injectors. The FMU will increase fuel with boost. Just using big injectors will be held at some max value once the ECM tables are maxxed out.
Anyway, use a boost ECM for boosted apps. if you are trying to squeeze out max HP. Using a non-boost ECM will brobably get you about 90% of max HP. Either you will be rich at low boost or lean at high boost. These are just estimates for the average tuner. Your actual results may vary.
Car: 1986 Firebird
Engine: LG4 305
So there's no aftermarket MAF system that can handle high CFM's?
Is the Accel Gen VII a MAP system?
How do MAP systems know when the turbo is on? Do they react that fast to the wideband O2 sensor?
Engine: 3xx ci tubo
It is not a question of ECM for you. You need to find if there is a MAF that will read that amount of CFM you have planned.
MAP systems know when "boost is on" by detecting that the intake pressure is greater than 14.7psi (free air). Just the same as a pressure gauge works for filling a tire. The ECM uses the pressure, air temp, and other stuff to figure out CFM.
React that fast? How fast is fast?
The MAP reacts to the turbo boost pressure(more pressure), not the O2 reading. A MAF reacts to turbo boost pressure (more air), not the O2 reading. The ECM reacts to the O2 reading and the MAF (or MAP) reading.
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
What about a FMU with Bigger injectors ? Change the constant in the .bin .....and let the FMU take over when the boost comes on ? I am runnnig the MAF setup aswell and was getting an FMU ( for starters) .
Would this solve the issue of useing the FMU as a crutch ?
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
Im happy with my 749ecm. My car has great drivability, gas mileage, and it was cheap. I drive my car to the drag strip(60miles) run 10's and drive back home. And get 22-25 mpg on the highway. Cant ask for anything else.
I suggested an FMU because, from reading his posts, it seemed like the original poster was a beginner to turbocharging, and the FMU is a little less complicated to get up and going because it does not effect part throttle drivability.
But you probably won't get into the 10's with one.
Engine: 3xx ci tubo
I am using a 730 ECM with the 749 code in it (essentially a 749 with high impedance-TPI/Mustang type injectors). I went with ford 42#/hr injectors. They are harder to tune at idle than stockish sized injectors. Part throttle tuning isn't that bad. I use the BLMs and a little help from a WB-O2. All WOT is done using the WB-O2.
For a beginner, I would go the FMU route and think about ECM changes later. I don't see why you couldn't get 10's with an FMU and timing retard box. Quarter mile is mainly WOT, so if the FMU is supply enough fuel and timing is reduced than there is really no difference from what an ECM would do (I think).
I would say the biggest thing is tuning WOT with a WB-O2 whether an FMU or ECM is used. Not making the most HP possible (best AFR) is really the only thing that will limit the ET.
Not saying it couldn't be done, but you need a lot of fuel to go 10's with a 3500# car, and stock injectors will need to work at very high fuel pressures to make it happen.
Engine: 3xx ci tubo
Yeah, I don't see 10's possible with stock injectors. I meant an FMU with 30#/hr or 36#/hr injectors. It would retain stock ECM with just a simple injector constant change. Not a complete ECM/code change. I think the stock 24#/hr with FMU are probably for about 450HP. Approx. very low 12's in a 3500# vehicle.
120psi sounds high. I have heard that some injectors fail to open at too high fuel psi. It is also harder on fuel pumps, but how often is the fuel pump really pushing that hard anyway. I would keep using it if it has been working fine.
Car: 1989 IROC-Z
So , what about 36lb injectors and and FMU with a 165 . Would that work ? Don't want to wash down the cylinder walls ....but don't want it to be lean up top ?
Car: 92 Formula 350
Impressive results for sure. How difficult was the tuning aspect of things? I don't think I would be as worried about the WOT mapping, but the idle/part throttle/cold start and other fine points I think could be a challenge for me to get perfect. I like using FMU's because they have worked well for me and are easy to use. I have no experience with ECM tuning.
Car: '70 Chevelle, '63 Corvette
Engine: 383, 327
Transmission: B&M 700r4, Muncie M-21
I'm surprised no one mentioned Megasquirt. www.msefi.com -- it'll handle a turbo setup just fine. There is no completely self-learning ECU. They all need to be tuned manually when bigger changes are made to the engine.
-Dave
-Dave
Engine: 3xx ci tubo
Yeah, I got an MS-II on the shelf. I didn't get a chance to try it on the Camaro this year. I will give it a try in the spring after I get the 749 code straightened out.
The only problem with the Megasquirt is that it is I/O limited. Once you use up the IAC pins there ain't much left.
J
J
120psi sounds high. I have heard that some injectors fail to open at too high fuel psi. It is also harder on fuel pumps, but how often is the fuel pump really pushing that hard anyway. I would keep using it if it has been working fine. [/B]
I've heard that as well. The install info included with Cartech FMU's seems to suggest it is just a myth. I have had no trouble with injecotor lock. My z24 runs the 120psi, my IROC is a more reasonable ~90psi.
Car: Supercharged Nitrous T/A
Engine: Motown 410SBC
Transmission: 4L80 - Compushift / Custom billet torq
Axle/Gears: 12b Moser 33/spl. /373 posi
I just buy a Fast XFI last week whit intake, fuel pump, trottle body, injector etc.., should receive all this this week !
Converting to Efi is a 5000$ thing,
Aftermarket is the way to go,
info on Efi:
http://hotrod.com/howto/113_0504_efi/
XFI :
http://www.fuelairspark.com/Products...mation/xfi.asp
Also look ;
Accel, Big Stuff, AEM, Electromotive, EFI Tech, Motec
Stock efi is damn a pain in ***...!!!
info on Efi:
XFI :
Also look ;
Car: 1986 Firebird
Engine: LG4 305
J
J
After a couple of weeks of reading about switching to the $58 bin and rewiring like the cyclone setup, I've decided MegaSquirt-II is the way to go. It's got everything now including ignition control, and can handle up to 20lbs of boost. Also incorporates the wideband O2 no problem. The only thing it doesn't have is a knock sensor. Pretty cool for less than $300.
Engine: 3xx ci tubo
[QUOTE]Originally posted by x007
info on Efi:
[url]
I guess if you have a spare $5K lying around. My carbed 355ci was converted to EFI twin turbo for $900+$2000 = $2900
Everyone likes different stuff. I am running all OEM parts except for the camshaft. That is, OEM chevy motor with the help of OEM Nissan turbos. Go with what ever works for ya.
Still haven't assembled that MS-II yet. I have to give the 730 with $58 code a fair chance. For me right now, the only advantage I gain with the MS-II is the alternate fire injector that would help at idle with my cheapy injectors. I have approx. 1.5ms PWs and 3.0ms would be a lot better.
I think the MS-II would be a great setup on a carbed vehicle. You get spark control & WB-O2 reading for less than aftermarket stuff.
Being able to record engine data is priceless.
info on Efi:
[url]
[QUOTE]Originally posted by junkcltr
You right , But i always look for the best..
Here is my setup whit the XFI ;
info on Efi:
[url]
info on Efi:
[url]
???? The best would be polished. Very nice setup though. Does that Vic JR EFI idle better with the injectors than a carb setup?
as for my Idle, I have a smoth idle at 800-850rpm whit my 950cfm Holley Pro (4 corner idle) & a Victor Intake,
So i dont think i will have lot better whit the Efi, btw this is a sequantial Efi (needed for a better idle & huge size of the injector i use), my setup is not finished yet .. still working on my car, i currently rewire the entire car, install the Efi & build a custom Dash (alum.).. So have some work for the rest of the winter.
Car: 1984 MSE #52
Transmission: TH700
Maybe a little late. www.massfloefi.com 1) no tuning (other than injector size. 2) Plug & Pray 3) Off the shelf parts. According to their web site and some of the car mags. I personaly don't know how well it works; but interested other than price. I'm still thinking bout carbs ,tho!!!
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
