best power adder for 305
Old Dec 13, 2005 | 03:10 PM
87_CAM_F41's Avatar
just curious what would be the best power adder for a 305 LG4??
im thinking spray, but i want ur guys opinion on this 1
its stock for now, but plan on modding everything in/on it
Old Dec 13, 2005 | 03:43 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Thast kind of a broad question . What do you want ? Is this a new motor ? Lots of stuff defines what is best for you .
Old Dec 13, 2005 | 08:53 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: best power adder for 305
Carbed
automatic
cheap
easy
_________
= nitrous
Old Dec 14, 2005 | 08:20 AM
87_CAM_F41's Avatar
id like to get mid 13's w/o a power adder, then get in the 11, 12 second range w/ power adder
Old Dec 15, 2005 | 09:52 AM
87_CAM_F41's Avatar
does any1 know this?
Old Dec 15, 2005 | 04:15 PM
high c's Avatar
Car: 86 iroc
Engine: yea it has one
Transmission: yea it has one of them also (im 2 for 2) :)
turbo+n20=go fast
Old Dec 15, 2005 | 05:38 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
For FAR less than you'd spend on a turbo or supercharger, you can install a direct port nitrous system and run 11's anytime you want.
Making the power wont be the problem with nitrous... keeping the car in one piece will be. At the very least you'll need a built transmission, and you'll need an upgraded fuel system... but you'd need those no matter which power adder you chose.
Old Dec 15, 2005 | 05:44 PM
high c's Avatar
Car: 86 iroc
if you have the fab skills and the know how you can make your own turbo kit for about 500
Old Dec 16, 2005 | 12:03 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I would be very impressed if you could do twin or single JY for less than $500. My current work in progress JY setup with intercooler will come out to $1200. And yeah, I am a cheapie when it comes to car stuff. The twins alone were only $100. The rest is other stuff. That is excluding the TIG I needed for the JY intercoolers.
J
Old Dec 16, 2005 | 05:12 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
cheapest way= spray and pray.
jaridjohn
Jul 8, 2024 03:49 PM
jhawkeye
May 25, 2022 06:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
Brcharrelson
Aug 26, 2015 07:47 PM
