HP on a roots-blown carbed Vette L98
Old Jan 5, 2006 | 01:16 PM
80smetalfan's Avatar
Car: 1989 IROC
Engine: LB9
Axle/Gears: 3.42 Posi
I'm thinkin about a Vette L98 (aluminum heads ) for my Cutlass, as the it's current 350 is in pretty rough shape. I'd be slappin a quadrajet carb. on it, along with my current headers and true duals system, and I was wondering how much power I'm looking at with this setup:
Vette L98 ('86, so cam specs are like 206 duration and .404 lift)
Headers/True duals
Wieand 144
1.6 ratio roller rockers
Rebuilt/Rejetted Quadrajet
MSD ignition setup
I assume I'd need to rejet the Quadrajet, and also pick up a new fuel pump, as I don't think the factory could handle the needed fuel flow.
Would expecting 350 hp at the crank be unreasonable?
Old Jan 7, 2006 | 11:23 AM
Car: 1989 IROC
Engine: LB9
Eh?
Old Jan 7, 2006 | 09:49 PM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
Re: HP on a roots-blown carbed Vette L98
350fwhp should be fairly ez to make with that combo
I'd get a book on tuneing that Q-jet though
Old Jan 10, 2006 | 08:05 PM
Damon's Avatar
Watch your compression ratio with a roots blower. I'm now on my 4th itteration of my roots-blown 383. It's been a little painful as I have a hard time getting it drilled into my head that 9:1 compression is TOO MUCH with a roots blower and pump gas!
My last engine with the Weiand 142 made 390HP to the rear wheels (420 torque as low as I could lug it) with 26* of spark advance, 8.7 compression, AFR aluminum heads and a modest cam. A few months back I turned the timing up to 28* and promply blew it to smithereens after 2 years of faithful service running at 26*. REAL touchy!
I've finally learned my lesson- I'm absolutely TANKING the compression on the 4th version of this motor: 8:1, no other changes to the combo. I should lose NOTHIG to the compression drop. I had to keep the timing so modest with the last combo I'm sure I was leaving a lot on the table. With this combo I should be able to run 28-30* safely on pump gas and make back what I lost by dropping the compression.
350 ponies at the flywheel? Like falling off a log if you don't blow it up from detonation.
BTW- I run a QJet on top of my blower, too. Tuned by yours truly.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
BDR
Nov 7, 2015 03:05 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
