supercharger cams
Car: 1992 T/A convertible
Engine: LB9
supercharger cams
Hi guys, I am planning out my mods for the spring and I need some advice. I am going to put an ATI procharger system on my 1992 T/A vert. It's a 305 tpi 5spd and there will not be much done to the engine apart from the procharger and headers/exhaust system upgrades. I figure while I'm in there I could also change the cam, So what I'm thinking of using is the comp 266HR-14. Have any of you guy's used this cam and if so how well suited is it for use on a relatively stock 305 with a procharger? I will also be switching to a 7749 computer and setting up a custom chip. If anybody has a better cam recomendation, I would like to hear about it.
thx
thx
That's fine, assuming that you want somethign on the tame side... you'd have to give a lot more detail about your combination and intended use for anyone to accurately say much more then that about it.
