supercharging my engine?
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
with my 10.75:1 cr,
what kind of power adder would I be able to push onto this engine?
Car: 89 Iroc & 88 Firecird & 86 Camaro
Engine: 350 TPI & 305 TBI & 305 Carb
With that compression ratio I would be comfortable with running about 2 to 3 pounds of boost on pump gas. Is this a street car?
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
Sell your heads and get some with 76 chambers that should lower your compression quite a bit. I'm also considering a turbo for my car I'm getting some 72 chamber dart heads.
I'm not saying that you can't do it, but that CR sounds a little high for boost.
84z96L31vortec
08-20-2017 12:16 AM
