Nitrous Braket Mounting Plate
Old Feb 27, 2006 | 09:04 PM
Blackhawk355's Avatar
Car: 1989 Firebird
Engine: N2O 355CID
ok i remember seeing this but it's for 3rd gens and 4th gens, its a mounting plate for the nitrous braket to put your bottle where the spare tire would be, does any one know a website or websites that i can get this from?
Old Mar 1, 2006 | 11:00 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
My NX kit came today and I was out in the garage trying to figure out what shape bracket needs to be fabricated to put the bottle in the spare tire well.
I then thought, "someone should build and sell brackets to put a bottle back here". I hope you're right and someone makes them.
Old Mar 1, 2006 | 11:07 PM
Car: 1989 Firebird
Engine: N2O 355CID
there is a place and its reasonablely priced too.
http://nitrousoutlet.com/outlet/prod...section_id=136
Old Mar 1, 2006 | 11:12 PM
GarageToys's Avatar
Thanks man, that's exactly what I was looking for.
I'm sure I could build one cheaper but if I spend all my garage time fabbing stuff I can buy, I'll never get the car assembled.
Thanks again for the link.
Old Mar 1, 2006 | 11:13 PM
Car: 1989 Firebird
Engine: N2O 355CID
no problem, i had to ask on camaroz28.com if anyone knew, lol.
Old Mar 2, 2006 | 09:24 AM
sstpres's Avatar
Nitrous Bracket
I looked this upmon 860 Performance. It says for 93 and up models. Has anyone actually used this on a 3rd Gen?
Old Mar 2, 2006 | 10:15 AM
Car: 1989 Firebird
Engine: N2O 355CID
i wouldnt think that there would be any difference.
Old Mar 2, 2006 | 10:38 AM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
you will hardly, if at all notice any difference between 3rd and 4th gen spare tire wells.
Old Mar 4, 2006 | 03:31 PM
GarageToys's Avatar
Well, in my constant plot to do battle with my own logic, I made up a cardboard template to build my own bottle bracket.
Old Mar 4, 2006 | 03:32 PM
GarageToys's Avatar
I got to looking at the 860 bracket and from what I could tell, it is only supported on one side (by the frame rail). The one I'm building will also bolt to the spare tire bracket so it's supported on both sides.
Excuse the mess. I haven't cleaned the inside since it came back from paint.
Old Mar 4, 2006 | 05:52 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Looks like a good idea!! Keep us posted on how the build goes.
Old Mar 10, 2006 | 07:00 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I use those NX stainless steel bottle brackets and have my bottle in my spare tire well... easy as pie to mount and is very sturdy.
Old Mar 12, 2006 | 01:37 AM
Ray102386's Avatar
Car: 83' Camaro
Engine: 355
Transmission: TH-350
Axle/Gears: Open...
Other Side?
Can this be installed on the other side instead of the spare tire location? In the "Glove Box" area?
Old Mar 12, 2006 | 07:17 AM
GarageToys's Avatar
Re: Other Side?
It could be, but I don't think the nitrous bottle would fit through the glovebox door hole. The plastic on the driver's side is one piece from hatch to driver's door & it would suck to remove it every time you want to fill your nitrous bottle.
Oh, I've got this fabbed-up now, I'll shoot a pic and post it.
Old Mar 12, 2006 | 10:20 PM
GarageToys's Avatar
Here it is- just sitting in place for now. I made the cardboard template and took it to a local welding/fab shop to build it. Yeah, I wish I would've bought the one from 860 performance. This one cost about $20 more and it's not even painted.
It's a good project if you have the means to do it yourself though.
Old Mar 13, 2006 | 12:47 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
looks good kevin, now just hit it with the .99 rustoleum semi-gloss and you're set.
Old Mar 13, 2006 | 01:40 AM
Ray102386's Avatar
Car: 83' Camaro
Engine: 355
Axle/Gears: Open...
Dimensions?
Could we get some dimmensions on here? If it works for you it will work for the rest of us.....
Old Mar 20, 2006 | 10:53 PM
GarageToys's Avatar
I'd suggest making a cardboard template to suit your particular car. With GM's notorious production tolerances, what fits my car may very well be different than what would fit your car.
It took me 5 minutes to make my template once I knew what basic shape it needed to be.
Hotrodboba400
Dec 10, 2019 07:07 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
FormulasOnly
Sep 6, 2015 10:42 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
