pinging problem
Old Mar 13, 2006 | 05:41 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
pinging problem
I'm getting a 3/4 throttle ping from my motor with supercherger on or on motor i'm using 91 octane also, i had 30 pound svo injector still same thing custom chip made still i broke the crank because of the pinging but full throttle will not ping if i stay in it.how does the egr work under boost.?
Old Mar 13, 2006 | 05:53 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
if it's pinging why did you continue driving it instead of pulling timing out of the motor?
Old Mar 13, 2006 | 06:55 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
This only applies if this engine is setup using the mods from your username engine description.
With a stock PROM and modified engine you will probably have some detonation/ping. Using a non-boost PROM creates a problem due to how it does fueling. At about 60-70% throttle it will not be in power enrichment (more fuel) mode. This can cause some detonation and timing may have something to do with it. You didn't mention if you use a timing retard box & FMU for fuel.
I had a similiar problem when I went with boost using a stock 1992 MAP ECM. At about 50% throttle I could make about 3 PSI of boost and the engine would start to ping due to it using the normal (stoich) fueling. Going WOT would make the ping go away because more fuel was added and timing is pulled. The only way to see this is to datalog. I then moved onto using the GM Syclone code and it is tuned much better for part throttle and WOT throttle.
How much boost are you running? Are you using an FMU? The 30#/hr are typically only good for 375-425 HP on a typical boosted engine (.55-.65 BSFC) without an FMU.
To get to the bottom of it you need to data log using the ALDL datastream. You can build an ALDL cable for less than $20 including an RS-232 cable and battery. There is software available for free that will run on a 386 or high laptop (cheap).
Old Mar 13, 2006 | 06:57 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Re: pinging problem
EGR is on or off according to road speed, TPS opening, etc.
At road speed and 3/4 throttle the EGR would be off in a stock PROM.
Old Mar 13, 2006 | 09:23 PM
antoine's Avatar
I had a chip made and it still had pinging problems. Will an FMU work?
Old Mar 14, 2006 | 09:29 AM
antoine's Avatar
also i remove 4degrees of timing if i hit it you canb hear alittle for a second.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
