Havent started motor in over two years, help....
Old Mar 19, 2006 | 05:58 PM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
So in the process of what ill just refer to as "life" i havent started my motor w D1 for over 2 years, it's been tucked away in a heated garage for that time, im finally getting around to working on it again, but quite frankly im afraid to start it, i plan to do this:
Empty out the gas tank, re-fill w good gas
Pull the distributer and manually pump the oiling system (after fresh oil change)
Drain and refill the cooling system
Change the fluids on the D-1
Is there anything else do you think i should do?, i just wanna try and make sure i dont blow it up......
Thanks guys.
Old Mar 21, 2006 | 11:28 AM
jocool's Avatar
Car: 89 Iroc & 88 Firecird & 86 Camaro
Engine: 350 TPI & 305 TBI & 305 Carb
If you are really worried about it some guys also like to pull the plugs and squirt a little lubricant into the cylinders. After a long sit this will be dry and upon cranking could shorten the life of your rings. Shouldn't be necessary though, I would just cross my fingers, fire it up, and rev it to the moon. Anyway good luck!
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
TheExaminer
Aug 26, 2015 04:59 PM
92projectcamaro
Aug 6, 2015 01:20 PM
L98GTA87
Aug 5, 2015 11:02 PM
