I Need More Power & Torque
Old Mar 20, 2006 | 12:59 PM
91Z28CAMARO32's Avatar
Car: 91 Z28 CAMARO
Engine: 383 STROKER TPI
Transmission: TH-700-R4
He Guys If I Take Out Mu 3.23 Ring Gear And Put In A 3.73 Ring In With My Car Have More Lowend And Will I Get Anymore Toque
Plus I Was Thinking Of Takeing The Tune Port System Off My 383 And Putting In A Elebrock 4bbrl DOUBLE PUMP Carb With A 700 Cfm Do Ya Think Ill Get More Hp Or Will It Be A Gutlas Motor Cuz If U Get The Right Setup U Can Get More Power Or Should I Gp With 36 Psi Injectors
Or And Is A A/c Bypass Pully Mean That Is Just A Pulley U Replace With The A/c Pump Or What
Old Mar 20, 2006 | 02:18 PM
Car: 91 Z28 CAMARO
need some input here
Old Mar 20, 2006 | 03:17 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
You are in the wrong forum . This is for forced induction Q's
Anyhow , the 3.73 gear , will make it feal more powerfull. But you should match it to the motor. Takeing the TPI and adding the 750 carb and stuff. Should make for more potential. How high do you spin this motor ? It may say if you NEED a 750 cfm carb .
Old Mar 20, 2006 | 06:18 PM
Steven89Iroc's Avatar
Someone needs to change the forum title to "Forced Induction and Nitrous" or something, we get these posts every few days it seems. People see "Power Adders" and say "Yeah, I want to add some power!". Heh
If you're going to post in the wrong forum, please type so we can understand you, at the very least.
deracer
Apr 11, 2016 12:04 AM
sailtexas186548
Aug 24, 2015 10:11 PM
zayne0
Aug 24, 2015 07:22 PM
InfinityShade
Aug 22, 2015 08:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
