Nitrous Switches
Old Mar 23, 2006 | 11:34 AM
BlackRabbitZ28's Avatar
Car: 1991 Z28 5-Speed
Engine: 305TPI
Transmission: 5-Speed T-5
Nitrous Switches
How do you spray your nitrous? Are you using a WOT, Window Switch, push button, or all of the above? Also when are you spraying? I mean I know not to spray at low RPM's but when do you start spraying? The top of 2nd?
I will be on street tires, so I was thinking of spraying in 2nd and see how that works. I want to run a window switch, and wide open throttle switch, hooked to a toggle switch. So I can hit it at the top of 2nd and sprays every time i'm WOT and in the RPM range. I want a max of 125hp-150hp.
Old Mar 23, 2006 | 12:51 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I have a digi window switch(but have not got it to work)
I have my activation switch on the same one as my fog lights.
Then I have a switch on the throttle pedal linkage that turns on a switch(basically a primary wot),
then that I have a wot switch based off of the tps
I spray right out of the hole and have not had problems with 75hp shot of dry nitrous. I use drag radials.
With street tires I would not use it till the upper rpms of 1st gear(4000 rpm). Other wise you will be spinning anyway.
Old Mar 23, 2006 | 02:33 PM
BadGirlIROC's Avatar
Car: 87 IROC-Z
Engine: 355 carb'd
Lots of accessories for our 3rd gens can be found here
http://www.jimmy-jams.com/
Old Mar 23, 2006 | 03:24 PM
Engine: 305TPI
Thanks, I really need to invest in a set of drag radials. I just want to know what my car runs at any given moment. not when I strip it and change the tires for the track.
Old Mar 24, 2006 | 12:33 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
so drive around on slicks. Great traction, all the time.
Veaceonee
Sep 29, 2016 08:15 PM
RacerM
Sep 28, 2015 04:25 PM
tglennon11
Sep 23, 2015 05:30 PM
327IROC85
Sep 23, 2015 12:11 AM
Randomtask2
Sep 10, 2015 08:37 AM
