Compression ratio with 9-12psi blower?
Old Sep 13, 2000 | 12:45 PM
Brett's Avatar
I'm rebuilding the LT1 I swapped as a 355 that's set up for a strong blower. Right now I have TRW forged 21cc dished pistons that should yield 9.5:1 down from stock ratio of about 10.2:1
Is 9.5 low enough to work effectively with a 12psi D1sc? Or should I order the 24cc dished pistons and drop the compression closer to 9:1?
1991 RS LT1
every imaginable bolt-on, and an all-forged 355 on the way with an ATI following in '01
2000 C5 Coupe
black/black 6-spd, optional polished rims, 'mostly' stock....
"So what DOES the back of a Mustang look like?"
Old Sep 13, 2000 | 01:31 PM
89ProchargedROC's Avatar
with 9.5 you are at the ragged edge of stock timing with 12psi. 9psi would be okay. But i would still bring it down to 9.0 or even 8.5 because maybe later you might want to up the boost. I think with 8.5 and an intercooler you can almost run 20psi and stock timing.
go with 8.5 or 9.0.
Old Sep 17, 2000 | 02:30 PM
bhoward's Avatar
I THINK YOU WILL BE JUST FINE WITH THE 9.5 COMPRESSION RATIO.I'M CURRENTLY RUNNING 9.1 RATIO BUT WISH I WOULD HAVE STEPPED IT UP A LITTLE MORE.
Old Sep 18, 2000 | 12:08 PM
FastBroker's Avatar
I'd go 9.0 or less, too... As eluded to, bumping up blower pressure later is a disease and too little CR is better than too much with a blower. Too much CR will beat the sheet out of any motor, never mind a blower motor. Call theblower mfr and get their recommendation. I bet 8.5:1...
Old Sep 18, 2000 | 04:13 PM
Guido's Avatar
Car: 2000 Trans Am
Im running 9.3:1 and Ill be running around 13psi if its close to what it was on my 355. Just make DOUBLY sure, that you get yours rings gapped for a blower. Its different than with a normally aspirated motor.
I think thats what killed me before.
-86 IROC
Vortech stuffed EFI 406 in progress
-=ICON Motorsports=-
InfernalVortex
Apr 20, 2021 11:31 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
buckeyecelt
Sep 24, 2015 05:50 AM
