where can I find a supercharger for accel pro-ram?
Old Oct 12, 2000 | 06:41 PM
motley400RS's Avatar
Well , any help would be nice . I was hoping to find one around 8 to 10 psi ? My cam has a LSA of 116 and duration of 204/int , 214/exh so ... the supercharger will be nice and happy . My compression ratio is 9.3 :1 . Please help I don't want to buy the TPI system just because nobody offers a supercharger for the Accel DFI Pro-Ram ! HELP!
Old Oct 13, 2000 | 10:37 AM
GMI FAST's Avatar
Dude, what are you talking about? Just buy the TPI kit and have somebody fab a new discharge pipe...
1989 Formula, 383", DFI, Mini-Ram, S-Trim Vortech, blah, blah...
Best ET: 10.796 @ 125.8 mph
TURBO 406 PROJECT STARTED!!!
Other expensive hobby: assault weapons/shooting sports
Employed at:
Hahn Racecraft
Accel EMIC/DFI Tuning
Turbosystems & Custom EFI
Member of Midwest F-Body Association
http://www.mfba.org
Old Oct 13, 2000 | 07:26 PM
hey , that's a great idea ! What would you suggest ? PAXTON ? VORTECH ? Thanks.
Old Oct 14, 2000 | 07:40 AM
Guido's Avatar
Car: 2000 Trans Am
I would recommend Vortech or ATI Procharger. Ive heard bad things about the P600B which is the compressor that comes with the procharger base kits but the largers ones like D1 and better Ive heard no bad things about.
And anything from vortech I think is good. Ive never heard one person say anything bad about them.
Old Oct 15, 2000 | 03:37 AM
89ProchargedROC's Avatar
Well, i wont lie, but ATI did have a bad batch of P600B blowers go out and they grenaded on some people. But GM had the bad batch of LT4 hot cam, does that mean that no one will buy GM again? Anyway, there has been a lot of people who have used the P600B and have had great results. But i would recommend if you are building a 400, not to use the P600B. the reason why is because you would have to spin it too fast to get the airflow you would need for it and that could spell disaster. So for a 400, go with the D-1. If it is a 350-355, go with the P600B. Finally, buy the pro-ram; go to www.precisionte.com and buy their pleun for it. problem solved.
Old Oct 15, 2000 | 07:26 AM
Will the ATI PROCHARGER P600B , witch is 12 lbs of boost and intercooled , work on a 9.3:1 copression ratio a full timing ?
Old Oct 16, 2000 | 03:11 AM
Barley. I run the exact combo and as long as you have the fuel it is not a problem. But i will admit to having turn down the timing a few degrees in this chillier weather because the colder air is denser and fills the cylinders more and can cause detonation easier.
Old Oct 17, 2000 | 02:20 PM
Anyone?
Old Oct 18, 2000 | 01:35 AM
ummm, did you read my post above? Any more questions just ask.
Old Oct 18, 2000 | 11:53 AM
GMI FAST's Avatar
Precision Turbo plenum is for Grand National V6 applications...
Employed at:
Hahn Racecraft
http://www.mfba.org
Old Oct 18, 2000 | 01:37 PM
Guido's Avatar
Car: 2000 Trans Am
I wondered about that Dan.
It looked like a close fit but Icouldnt tell.
Also the bolts for the TB wouldnt match at all.
Old Oct 18, 2000 | 02:36 PM
Thanks!
Old Oct 18, 2000 | 03:20 PM
Actually, i emailed them about it and they said they can make one that will fit carberated intakes. $180
Hotrodboba400
Dec 10, 2019 07:07 PM
BAMiller
Sep 14, 2015 06:38 PM
Jackrabbit501
Sep 2, 2015 09:14 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
