Nitrous question-for 305 tbi
Old Oct 11, 2000 | 03:08 AM
mike ghoul's Avatar
i have a 1990 camaro rs with a 305 tbi, it has about 95,000 miles on it, and other than bad valve seals is in good condition(about a 1/2 quart of oil between changes).
My question is this: If i add nitrous, am i just going to blow the motor up after a couple of hits? I was thinking of about a 50-100hp hit, how much can the motor handle(and still be reliable)?
As far as mods i have intake,headers,exhaust,ignition,3.73 gears, shift kit,fast chip prom,suspension,etc.
Any opinions anyone can offer would be appreciated. I want some more power, but would also like to have this engine last another 1.5-3 yrs.
When adding nitrous i assume it would also be wise to put on an AFPR correct?
thanks for the help.
Old Oct 16, 2000 | 11:52 PM
mike ghoul's Avatar
just wanted to move this one up top so some one might give me and answer. ha ha.
Old Oct 18, 2000 | 07:21 PM
84bird's Avatar
your good for a 100 shot and probably 150 shot just make sure you use it above 2500 rpm and have it set at wot only . Check your fuel supply to make sure you can supply enough gas. Good luck and remember to use it only when needed otherwise you scare the money away.
xkingcodex
Feb 12, 2020 07:43 PM
Dwayne614
Sep 28, 2015 08:33 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
CamaroGuy350
Aug 26, 2015 05:11 PM
