What Procharger psi can I safely run on a stock rebuilt 350.
Hey guys. I just realized the funds on my beautiful 383 are going to be cut short so I would like to put a supercharger on the 350 and then probably just move it to the 383 when I had the money to finish the project. The 350 was completely rebuild 7k miles ago so the motor is very fresh, but as far as I know, none of the short block has anything stronger than stock.
This worries me obviously because I've seen enough blower-equipped cars that always had the first engine blow. So how many psi can I run with my 350 w/out the worries of kaboom? Just to be on the safe side I'd plan on getting a timing retard controller.
Thanks.
The '82Z
Hugger Orange
383 4 bolt main
3000 lbs
Bad cornering
NOS Sportsman Fogged
10 bolt braker
Coming to a street near you in the spring...
The car's website
Thanks.
The '82Z
Hugger Orange
383 4 bolt main
3000 lbs
Bad cornering
10 bolt braker
The car's website
crazeinc,
You can run either a 9# procharger w/intercooler safely without a ignition retard or you can run a 6# vortech kit which comes with a ignition retard box and no intercooler...both kits are comparable in cost...it's up to you to decide which kit you want...i just recently purchased a 10# ATI procharger (D1sc) for my 88 iroc...which for the most part is stock except for the exhaust system...I'm hoping to run in the 12's....but only time will tell...
check out my webpage for pics of the supercharger install....
later,
MÅN¡ÅÇ ©
88 IROC 5.7L,edelbrock TES,random tech cat,borla exhaust,chip,sfc,accel wires,airfoil,k&n's,ETC..
and soon to be supercharged
http://maniac.megamania.com
later,
MÅN¡ÅÇ ©
