got dusted by mustang help!!!!
Old Jan 1, 2001 | 03:51 PM
millertime's Avatar
I have a 88 ta 305 MPFI stock need some bolt on hp. were to start?? best for the $$$ Thanks
Old Jan 1, 2001 | 07:50 PM
superiroc's Avatar
Buy a catback and headers and put the nitrous to it. If you don't want nitrous get a set of trick flow heads super ram or mini ram and cam. Stock trick flow heads will make more power then any other except maybe afr 190, its close? If you want do dust a mustang or 4th gen camaro you gonna need to spend more then a couple hundred. Oh yeagh you need a 350 or else nitrous is your only option unless you wanna spend mega bucks.
Old Jan 1, 2001 | 08:00 PM
superiroc's Avatar
After a little more thought I came up with a game plan for you.
BUY the following
Nitrous express kit $440
Fuel safety switch $40
RPM window switch $75
catback $250
24# svo injectors $220
Jet it for 125hp and you should be fine. If you educate yourself on nitrous and learn how to use it you won't have any problems, ignorance is the cause of most nitrous problems. If you have any money left over get a set of headers. Also free mods port plenum, take out MAF screens and get a KN filter. You might want a set of drag radials for good street racing traction i have a knew set for sale.
Old Jan 1, 2001 | 10:52 PM
85F-body's Avatar
how much do the drag radials cost and also i think that you should get a super or turbo charger depending on how much you want to spend
Old Jan 1, 2001 | 10:57 PM
superiroc's Avatar
$200 they are slightly used maybe 600 miles like brand knew
ndndndnd
Sep 28, 2015 08:00 AM
okfoz
Sep 22, 2015 03:37 PM
Thirdgen89GTA
Sep 12, 2015 08:39 PM
