what is the cost to refill nitrous how long does it last
Old Jan 19, 2001 | 10:19 AM
travsirocz's Avatar
Car: Two 1987 Iroc-Z Z28s
Engine: 5.7 TPI ZZ4 1.6 Roller Alum. Head
How much does it usually cost to fill a 10lb tank. How long will the tank last with my setup.
1987 Camaro Iroc-Z Z-28 with a TPI 5.7
-Ram Air,K&N Filterchargers, Gutted Mass
Airflow Sensor, Throttle Body Airfoil,
Edelbrock TES Headers and Y pipe, Gutted
Cat, 3 inch exhaust, Flowmaster
-Hypertech Thermomaster Chip, 160 deg Stat,
Adjustable Fuel Pressure Regulator
set at 50 psi, MSD Cap, MSD 8.5mm wires,
Accel Coil, MSD 6AL Ignition Box, Accel
Plugs
-Richmond 3.73 Gears, B&M Transpak,
B&M Rachet Shifter, Energy Suspension
Products
-Fiberglass Cowl Induction Hood,
Purple Neon License Plate Frame,
16X8 Rims with BFG 245 50's,
Pioneer Deck, 2 JL 12's in a Q-Logic
Box with a 300 Watt amp
What you can put between your ears,
no one can take away.
Old Jan 19, 2001 | 01:03 PM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
I've seen it as cheep as $2/pound and as much as $5/pound. Average most places is about $3 or $4 a pound. Depending on jet size you'll probably get about a dozen to 15 runs or so per fill.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
My IROC-Z
EFI Performance Club on Yahoo
Club IROC-Z
Old Jan 20, 2001 | 01:09 PM
SpRaYd91Z28's Avatar
I pay 2.75 per pound, run 125 shot, and get about 8 full runs....the first ones always the fastest, being that my bottle is at max pressure.
Zach
Mods: Headers, K&N, 2k Stall, Custom shiftkit, 125hp Compucar N20 kit. Nitto 555R Drag Radials.
Old Jan 20, 2001 | 10:30 PM
irocluke's Avatar
a bottle warmer will help that
www.irocluke.freeservers.com
z 28 jari
Sep 14, 2021 10:03 PM
corey8084
Sep 17, 2015 02:56 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
Street Lethal
Sep 7, 2015 01:09 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
