Custom prom with my paxton 10lb WOW
Old Feb 20, 2001 | 06:44 PM
theformula's Avatar
Had "member who wishes to remain anonymous" burn me a custom chip for my setup (see mods). He designed the chip for a supercharger, stock ecu, and 24# injectors. The car runs beautifully. Absolutely no knock or detonation all the way to it's 5500rpm limiter
The car has actually never run better.
This just goes to show you , you do not need a syclone ecu for sd blown cars. Ed Wright has said the same.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL,MSD boost-master,Holley 9mm wires,Ac delco R43ts plugs,custom chip,Ford SVO 24# injectors,Bosch O2sensor, Bosch in-line pump(w/stock pump), SLP 1 5/8" headers,SLP catback,short shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
[This message has been edited by theformula (edited February 20, 2001).]
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
dusterbd
Sep 29, 2015 08:40 AM
