what cam to run?
what cam to run?
i have a mildy built 350.it has about 9.2:1 compression,bored .040 over,flat top pistons with valve reliefs,decked block,stock stroke crank,etc. the hears have 194 intakes.i am runing a old vete dual-plane mid rise(the hood wont fit but it isnt really tall)
what kind of cam would be the choice for me?
oh i want to run a hydraulic lifter cam
86 camaro:was a v6 car with stick,converting to v-8..NEED A V-8 T-5!!!!!!!!!!email me if you have one!!!
350 cylinders bored .040 over.a little oves 9:1 compression(getting a blower some day when im rich lol)line bored.deck milled a little(was pitted)
trw forged pistons with summit stage 2 polished rods with arp bolts.
194 intake valves,pocket ported,gasket matched,and polished ports,old vette intake with new zinc 650 holley
ase certified for a few years,learned alot though
working on freakin NEONS ,cirruses,tauruses,cobras(wel at least they look nice lol)and intrepids all day makes me drink too much
good job security though
comeon people!!!help!!
oh i dont waht it to idle at 4000 rpm and only make power at 9000 rpm.
it can idle somewhat lumpy but i want to make power in the range best for my heads,intake+carb setup.3500-6500 powerband?
mike
mike
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Tell me the following things...
Type of blower
size of carb, if any... are you running EFI?
rpm range
converter
trans type and rear end gear ratio
I MIGHT be able to help.
Type of blower
rpm range
converter
oh sorry.650 holley.no blower(later on down the road il get one)
oh yeah..lol ahh power range from like 2000-6000ish....it can idle lumpy i just dont want it to idle at 400rpm. t-5 so any stall i want!!!!
mike
mike
i meant i dotn want it to start to idle at 4000 rpm.i cant type sorry bad week at work man
neons from hell!
neons from hell!
1988iroc350tpi
Aug 14, 2015 07:52 PM
