Nitrous + Propane?
Old Feb 18, 2001 | 01:11 PM
BlackBowTie's Avatar
Nitrous + Propane?
Has anyone seen the N20+Propane kits used on an F-body? I just recently witnessed this on a viper kit from BTR.
Also, Has anyone adapted the alchol injection from the GN to a F-body w/ blower?
BBT
Old Feb 22, 2001 | 10:26 AM
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
i added alki to my z it works great it has binfits too
it raises the octain 10 points plus it helps to
cool down my intake charge from my blower
and its easy to do.
1 for safty reasons i used a ad 4 gal AD tank
2 a 7 pound in line pump
3 high presure nilon hose
4 a pressure switch agustible "set at 5 psi"
5 one nos fogger nozzle with jet 028 (may vary with diferant boost levels)
i thank thats it.
this thang also kept me from buying race gas all the time
as for puting this kit on a non mod motor it probly
just make it run rich unless you had high compression
and would help keep away detonation.
check out my simple page
http://darcom.home.texas.net/
Old Feb 22, 2001 | 05:16 PM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
The BTR kits have good potential but $1900 is a bit steep for a nitrous kit.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
My IROC-Z
EFI Performance Club on Yahoo
Club IROC-Z
Old Feb 23, 2001 | 10:02 PM
aboadnan's Avatar
I talked to a guy from NOS a while ago and
he said you need a smaller fuel jets
because propane presure is 90 psi (i think)
that's using carb plate so whith FI may
you want to play it safe and use a little
bigger jet and go down untill you get
the best performance.
Infested
May 22, 2018 11:56 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
bbsr72
Apr 2, 2016 09:12 AM
anesthes
Sep 18, 2015 12:34 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
