turboing questions
turboing questions
i have been looking around and i cant seem to find any fuel stuff for twin turbo set ups, also if you are running twin turbo and you say 7 psi is safe then what are you talking about both turboes adding to 7 psi or 7 psi out of both
o yeah by the way why i ask is because im doing a twin turbo set up and if i go fuel injection then what injectors or what do most people do
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Twin turbos do not add the individual the boost.
Turbo #1 makes 7 psi + Turbo #2 makes 7 psi = 7 psi at the intake
You just double your maximum flow. Such as Turbo #1 supports 300 hp + Turbo #2 supports 300 hp = 600 hp potential support at the intake
Do some searching and you'll find good answers. Search feature can be very handy.
