what heat range of spark plugs would you reccomend for my setup w/in
Old Feb 27, 2001 | 02:30 PM
bad camaro RS's Avatar
what heat range would you reccomend? i will be running Nos what brand or type are good for nos thanks mods on sig
1992 camaro RS
195cc AFR heads with compition port work milled to 58cc "10.9 to 1 compression"
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
compucam 2032 with 1.65 full roller rockers
497-510 LIFT 214-220 duration
msd6AL
1 5/8 headman headers
2 `1/2 flowmaster exuast
k&n filters gutter air box gutted maf"no fins no screens"
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
accel 8.8mm wires
B&M mega shifter
gutted maf/airbox
hotchkis lower control arms
3" exhuast cutout
homemade cold air intake
2000 tci stall
700R4 with B&M shift kit edelbrock water pump
new best ET 13.5 @104.66
no times with new afr heads hoping for 12's on motor
Nos to be installed soon
Old Feb 27, 2001 | 07:00 PM
Chuck Everly's Avatar
Moving to Power Adder board. You may want to post this in the General Engine board also.
Old Feb 28, 2001 | 02:12 PM
MSD tech's Avatar
bad camaro RS,
I would recommend at least one step colder preferably two steps colder then stock. Ideally as cold of plug as you can run with out fouling them under normal driving conditions. Stick with a standard style plug there is no need for the HYPE plugs. Depending on how much NOS you are going to spray depends on how much plug gap. I would start at the factory gap and work your way up in .005 increments. There is not a need to exceed .065.
Thanks,
Joe
Old Feb 28, 2001 | 05:06 PM
The ODB's Avatar
it is easier to powertune with a very wide gap of .050 or a little more because when you reach the lean limit the misfires will be more obvious. Then you tighten the plugs down to around .033 or tighter to eliminate the misfires.
A colder plug will reach a higher power level without detonation.
The hotter burn you have in the chamber, the colder you want to go with the plug.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Feb 28, 2016 03:33 PM
tricky1
Aug 23, 2015 01:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
