N2O setup possibilities
Old Feb 27, 2001 | 02:22 PM
mefreema's Avatar
Would it be possible to setup a 50-75-100 hp shot without retarding the timing? If you used an second fuel tank and had your electric pump feeding from it to you injection plate. Then you could run 104 or 107 octane fuel in you second tank to cut down on detonaton. Or even Alcohol, methonol, nitomethane or something like that. This way I would not have to drive with retarded timing all the time haha... I know I could get a ignition that could retard timing when I hit the juice but I dont have one yet so I'm exploring other possibilites and am just plain courious too.
Old Feb 27, 2001 | 03:05 PM
The ODB's Avatar
I've already done it and it works fine.
note, you cannot use methanol unless your fuel system is corrosion resistant (not aluminum).
You will have to go with very high octane of over 110 for it to work. The amount of fuel supplied by your NOS system will be a small amount of the total fuel injested by the engine. You low octane fuel will dilute the high octane due to this ratio.
I did still run a retard on mine because my cylinder pressures were very high.
ODB
Old Feb 27, 2001 | 03:23 PM
mefreema's Avatar
So maybe a bottle of octane booster that is supposed to treat a whole tank of gas could be mixed with 1-3 gallons or so to give you a real hi octane rating. Like 120 or so?
Old Feb 28, 2001 | 12:25 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
<font face="Verdana, Arial" size="2">So maybe a bottle of octane booster that is supposed to treat a whole tank of gas could be mixed with 1-3 gallons or so to give you a real hi octane rating. Like 120 or so?
</font>
It doesn't work that way. You are lucky to gain 3-4 points with an octain booster even when very large quanities are used. You wouldn't get even close to 100 octain. Even Sunoco Maximal™ only has 116 pump octain rating. If this would work Pro Stockers would be doing it instead of buying this "high rent" gas.
You could set up a separate fuel system & run race gas in it but it wouldn't be any cheaper than getting a nitous timing retard.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
My IROC-Z
EFI Performance Club on Yahoo
Club IROC-Z
Old Feb 28, 2001 | 11:54 AM
mefreema's Avatar
Sounds like I will have to live with the current setup and just invest in a better ignition system down the road. Thanks for all the input.
Old Feb 28, 2001 | 05:28 PM
The ODB's Avatar
he's right it doesn't work that way. Don't even try to run octane booster like that.
you will need to use something like CAM-2 racing fuel of 112 or higher for the cell.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
