nos low pressure cut off switch a few questions
Old Mar 14, 2001 | 06:51 PM
bad camaro RS's Avatar
what fittings and where can i get em to adapt cut off switch to my fuel rail is fuel rail valve best place to put it?
Old Mar 15, 2001 | 02:52 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
The rail is as good a place as any.
You can istall it anywhere in the fuel system after the fuel filter, and before the fuel solenoid. A lot of people just install it anywhere inline between the fuel pressure test port on the fuel rail and the solenoid. NX has a small manifold that has a #4 AN female on one end, a #4 AN male fitting on the other and a 1/8" NPT female port in the middle. You can disconnect your braided fuel feed hose at the fuel pressure test port or at the fuel solenoid and install it inline there. They are also available with #6 AN fittings, but the stock pressure test port (on TPI) is # 4.
I'm using two of these. One is directly on the fuel pressure test port for an electronic fuel pressure gauge sender. One is directly on the inlet of my fuel solenoid for the fuel pressure safety switch.
You can see a picture here, http://www.geocities.com/irockz4me/i...pics/eng2.html
You can't directly see the adapters but you can see how they are plumbed, & the sender & switch. The adapters look like the silver aluminum nitrous filter that is on the inlet of the nitrous solenoid, but they are a little smaller.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
My IROC-Z
EFI Performance Club on Yahoo
Club IROC-Z
[This message has been edited by IROCKZ4me (edited March 15, 2001).]
1992 Trans Am
May 10, 2023 07:19 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
jackhammer
Aug 15, 2015 10:04 PM
