I have a few questions on the effects to the powerband from supercharging
Old Apr 3, 2001 | 11:22 PM
spearson's Avatar
My questions are based on using a TPI with ported plenum, large tube runners, and larger base, all on say a stock motor.
I know that the tpi suffers in the high rpm range, how does supercharging help out in the upper rpm ranges?
How about low range rpm?
How about with fuel econ and all around daily driving?
Emmisions?
If a person is running at say 8psi boost, is it always running at 8psi, or is that the max it gets to under WOT?
If any of these questions are answered in a article somewhere, could ya point me at it?
Thanks again
Steve
Old Apr 3, 2001 | 11:32 PM
The ODB's Avatar
what type of supercharger are you talking about?
Old Apr 3, 2001 | 11:50 PM
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
I have a vortec on mine and run 14psi
but if i had a larger pulley i could drop
it to 8 psi and then that would be the max
at WOT.
as for drive abilaty it will allways
be drivable just depends on how much boost
and gas grade the more boost the more
octain.
check out my simple page at:
http://darcom.home.texas.net/
388 SuperRam, DFI, Vortech R trim ,N.O.S.,alki injection,
Dart sportmansII heads,50 pound injectors, Headman full headers
duel 3' exhaust,and Flowmasters, Ford nine inch with 370's
Ronal rims with Nitto drad raidals.
Old Apr 4, 2001 | 12:09 AM
spearson's Avatar
What kind of supercharger?
I am not sure, just started looking into superchargers. Basically I am looking at the general case scenario.
Old Apr 8, 2001 | 10:14 PM
The ODB's Avatar
there are several different types of superchargers out there. They work very differently and produce very different results. There's a book called 'street supercharging' that would be good info for you and probably answer all your questions and more.
I can't really give you a good answer without knowing which type of supercharger.
ODB
Old Apr 9, 2001 | 08:35 PM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
I have the street super charger book, It seems to be more for the carb 144 b&m type of blower (roots style).
86 Tramaro 90% Trans Am/ 10% IROC/Z (nose, hood,& fenders)
Trans Am Mods as of 1/10/01
3inch
T.E.S/Flowmaster setup,gutted cat,gutted maf,relocated mat,373 gears,upgraded factory chip,255 liter h/press. walpro f/pump & throttle body coolant bypass
njdaewoo@excite.com
Old Apr 12, 2001 | 06:22 PM
The ODB's Avatar
centrifugal superchargers are not a good match at all for a long runner TPI system.
Old Apr 13, 2001 | 12:26 PM
a73camaro's Avatar
ODB, why is that???
Old Apr 13, 2001 | 02:22 PM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
The boost curve is a square relationship so that most of the boost is only in the high rpms. A roots blower is linear, so you'll have more boost down low where the TPI doesn't choke it.
Old Apr 14, 2001 | 10:58 AM
a73camaro's Avatar
So wouldn't it be better to "force" in air at the upper RPM's when the intake is not keeping up with the demand??
Old Apr 14, 2001 | 11:00 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Sure, if your goal is high rpm power. IMHO, why fight it? Toss on a super/mini/ramjet on there first and pick up that extra 50 hp.
A.
Frozer!!!
Jan 19, 2024 04:55 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
mikey8494
Aug 22, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
