Relay with purge?
Old Apr 13, 2001 | 09:53 PM
89GTA5spd's Avatar
Relay with purge?
Curious as to whether anyone runs relays for their purge solenoids? I was just wondering if I should spring the extra $4 and throw in a relay to protect the solenoid.
Old Apr 13, 2001 | 10:30 PM
Bob Wooten's Avatar
Iwould think that one small solenoid would not need a relay. I dont think that it draws more than 1/2 an amp. any quality switch ought to work.
BW
Bob Wooten
71 Camaro, 91 EFI
r71chevy@earthlink.net
www.r71camaro.homestead.com
Old Apr 16, 2001 | 03:49 AM
89GTA5spd's Avatar
I think i might just throw a 5amp fuse in there. I am running it with a 20 amp switch, so I assume nothing bad will happen.
Old Apr 16, 2001 | 05:51 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
A fuse is a good idea on anything electrical.
A relay won't protect the solenoid. It protects the switch. A relay allows you to use a switch that is rated for less current than the load it controls.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
My IROC-Z
EFI Performance Club on Yahoo
Club IROC-Z
Old Apr 16, 2001 | 09:02 AM
Bob Wooten's Avatar
A fuse is an automatic for me so i did not consider that it would not have one. specially on something like a coil that has the potential to pull large current in a failure, not like a bulb or something that just typically just opens & stops working.
Sorry for the assumption.
BW
Bob Wooten
71 Camaro, 91 EFI
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
