installed paxton now code 33 too much air!! no kiddin, now what?
Old Apr 29, 2001 | 04:44 PM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
ok just got the paxton put on took it for the first test run and I get a code 33 out of it what do I need to do to keep this code from setting?
'87 Monte Carlo SS,with '89 IROC 350,700 trans, blew up 3.73 posi stuck with crappy 2.73's neeed gears! hooker headers, flow's 2 1/2" exhaust true dualls, recently installed a set of alum vette heads 58cc, new cam for a paxton, waiting on paxton till I can find a good rearend. So if anyone knows where a buick GN 8.5" rear is let me know.
Old Apr 29, 2001 | 05:50 PM
maniacc's Avatar
monte,
Check your connections at the MAF, especially if you had to extend your harness to relocate your MAF sensor, i am going thru this very code right now, i installed a ATI procharger,the first couple of trips out were OK, but then i got a code 36,(burn off relay fault), i replaced the relay's and reset the computer, went for another cruise, then BAM!!!, code 33, i followed all the diagostics steps (courtesy of Willie), 3 times and came to the conclusion that my MAF sensor(13yrs old) is bad, so i ordered one from http://www.gmpartsdirect.com/
later
larry
MÅN¡ÅÇ ©
88 IROC 5.7L,edelbrock TES,random tech cat,borla exhaust,chip,sfc,accel wires,airfoil,k&n's,ETC..
and NOW supercharged!!!
http://maniac.megamania.com
toronto formula
Nov 10, 2015 06:17 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bryan623
Aug 10, 2015 11:33 AM
