Turbocharger idea
Old May 22, 2001 | 10:46 PM
One Eyed Jack's Avatar
Turbocharger idea
Okay, knowing that I'd need to get custom headers for a turbo, why not mount the turbo somewhere down the exhaust line, and run an air intake line all the way back? Im sure there's plenty of room in place of a cat, right?
1992 Pontiac Firebird
- 5.0L V8 TBI
- Automatic Trans
Old May 22, 2001 | 11:15 PM
Jester's Avatar
Theoratically it can be done. I once saw a 7 or 8 second car that had the turbo mounted where the passengers seat used to be. But no there isn't enough room where the cat used to be...to even be an option you'd have to cut the floor and recess the turbo up quite a ways. Plus the farther back you put it, the more lag time you will get.
I wouldn't call it a feasable idea if you wanted to keep a passengers seat.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old May 22, 2001 | 11:17 PM
What about where the winshield wiper fluid goes? any other places?
- 5.0L V8 TBI
- Automatic Trans
Old May 23, 2001 | 06:08 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
The obstacle to overcome would be getting the oil back to the crankcase. I've been quietly designing a single turbo setup for my Durango where I was going to do the same thing. A company called "Aerocharger" (aerocharger.com, duh) makes a turbo with a self contained lube system, but they are not large enough. A twin setup might be large enough to feed a V8.
Callaway used a separate oil drain pump for its low mounted turbos.
It's very important that the oil drain from the turbos has *no* restriction at all, does not cause a trap (think under your sink), and enters the oilpan above the oil level. Otherwise, the oil will not easily drain from the center section, and you'll have seal problems, as well as the oil coking onto the shaft and bearings. HTH!
(Before I snapped the driveshaft)
After
Andris Skulte
Skulte Performance Designs
Z28tt-89 IROC T56 DFI Twin Turbo
http://www.skulte.com
Edited to fix broken image
[This message has been edited by askulte (edited May 23, 2001).]
Old May 23, 2001 | 09:14 AM
Bobalos's Avatar
Boy I HATE it when that happens. this is a good sign though. if you are making enough HP to twist up the drive shaft that means that both you are making some HP & that you are putting it to the ground
BW
Bobalos
aka Bob W.
www.r71camaro.homestead.com
r71chevy@earthlink.net
gta892000
Aug 11, 2019 11:16 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
