vortech and ati intercooler
Old Jun 5, 2001 | 06:48 PM
WARDL98GTA's Avatar
IS IT POSSIBLE TO HAVE A VORTECH SUPERCHARGER WITH I THINK 6-8 PSI AND USE A ATI 2 CORE INERCOOLER AND HAS ANYONE INSTALLED ONE ON A TRANS AM....WOULD A D-1 OR D-1SC WITH 12 PSI WORK ON A STOCK L98 TPI WITH 63,000 MILES OR IS THAT TOO MUCH FOR A STOCK ENGINE???????
Old Jun 6, 2001 | 12:06 AM
89ProchargedROC's Avatar
well being that i've installed both an ATI on both a camaro and GTA and installed a vortech....the intercooler system *might* work. First you would need to rotate the compressor housing on the vortech to face the driver side fender, it memory serves me correct that would put the outlet down low while facing the fender.
then you'd have to install the intercooler system and then you would just have to connect it to the blower with some custom ducting because the vortech blower sits closer to the engine than the ATI one does
Old Jun 6, 2001 | 09:32 AM
89 Pollo's Avatar
Car: 89 Formula
Engine: 355
That is what I did. Unfortunately, you can not turn the outlet since it hits the bracket. You can send it in and have the blower exchanged for the outlet that faces the firewall. I ordered 2 silcone molded 90's and will tie the 3" 90 by the horns in somehow. I am still in the process of doing that. I put the intercooler in in one day, it was no real problems. I modified the kit to accomodate the RAM air set up and charcoal canister. It looks great!
Mark
Old Jun 6, 2001 | 10:30 AM
Guido's Avatar
Car: 2000 Trans Am
Can you snap some pictures when you are finished Mark?
-86 IROC
S-Trim, Speed Pro, AFR
this years goal: 10.50 @ 130+ mph
-=ICON Motorsports=-
Old Jun 6, 2001 | 11:31 AM
89 Pollo's Avatar
Car: 89 Formula
Engine: 355
Sure will.
Mark
Terrell351
Jun 13, 2021 01:13 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
anesthes
Sep 30, 2015 07:48 AM
MoJoe
Sep 15, 2015 12:50 AM
