Shot in 150. Can I go to 175 plus?
Old Jun 11, 2001 | 10:41 AM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
I want to know if anyone has ran more than 150 shot on a stock short block L98. I can pull timing with my msd and have enough fuel, but I am not sure if I can swing it.
1991 Firebird
350 L98 (was a 305 TBI)
T-5 transmission
Edelbrock TES and cat back
Accel manifold
NOS
subframes
jegster torque arm
MSD Digital 6
AFPR
Lakewood lcas
Hurst linelock
SLP cam (206 212 .480 .486)
relocated battery
cold air
Hypertech chip
centerforce df clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
a/f gauge
autopower rollbar
12.44 @ 114.63 juiced uncorrected
13.549 @ 102 non juiced uncorrected
Old Jun 11, 2001 | 10:59 AM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
150 plus shot of spray on a stock short block is living on the edge. It may last a little while but not for long.
Old Jun 11, 2001 | 11:01 AM
Car: 1991 Firebird
Engine: 427 LSX
how do you know? I am not convinced with that "living on the edge statement"
Old Jun 11, 2001 | 05:34 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
I ran a 150 shot for 4 years(good amount of use) and had zero problems with it. Like I say, Go or Blow :-)
Old Jun 13, 2001 | 01:40 PM
Car: 1991 Firebird
Engine: 427 LSX
No, see I want more than 150 now.
Old Jun 13, 2001 | 10:53 PM
One Eyed Jack's Avatar
don't hurt it, please
1992 Pontiac Firebird (stock)
- 5.0L V8 TBI / Automatic Trans / Every option, excluding leather
- Killer car audio system:
  • Aiwa CDC-MP3 head unit
  • Rockford Fosgate 360a2 amp
  • pair of 12" MTX Thunder 5000s in a custom box
  • Pioneer 3-way 6x9s, soon to add more more more!
Old Jun 13, 2001 | 11:15 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
I'm using a ~175-200 shot in my stock Motor at the moment and I've only ran 3 bottles threw it at that shot..
So far so good...
I think it depends on what system you have
Dry or Wet?
Hecubus
Check out my new site http://www.geocities.com/hecubus91
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/Nos Wet Plate System currently ~200hp shot/ 155lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel,Air-fuel, voltage & Oil Press Guage's/MSD 6al/ Blaster coil/ Optima,Yellow top batt.
"I spent all my money on race cars, beer, and Broads... The Rest I wasted"
[This message has been edited by Hecubus (edited June 13, 2001).]
Old Jun 14, 2001 | 10:09 AM
Car: 1991 Firebird
Engine: 427 LSX
I am running a wet system. What n20 jet do you have?
Old Jun 14, 2001 | 07:57 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
I'm all the way up to 78 and my fuel is down to a 32
but the small silonids only will flow up to a 75 jet
I just didnt have a 75 ..I've heard from a local speed shop guy that they will flow a little more though
Hecubus
Old Jun 14, 2001 | 09:56 PM
Car: 1991 Firebird
Engine: 427 LSX
What brand of system do you have? What is your fuel pressure? What do you mean down to a 32 on fuel? Seems a little small. Thanks
Old Jun 15, 2001 | 07:30 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
It's a N.O.S. system
I running about 48 fuel pressure most of the time with vacume
yes that is what I ment by all the way down
that fuel jet is really small for that no2 jet (was having way too rich mix) ..... I suspect that my 255lph pump was too much flow for the stock jetting
Hecubus
Old Jun 15, 2001 | 07:31 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
sorry Doubble post
Hecubus
[This message has been edited by Hecubus (edited June 15, 2001).]
Mirror Image
Oct 29, 2017 09:51 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
FueledSoul
Sep 30, 2015 09:18 PM
JSDaddy189
Sep 26, 2015 03:50 PM
obeymybird
Sep 25, 2015 09:43 AM
