More Power
More Power
I have a 1991 Z28 Camaro with a 5.0 305 engine in it. Ill I have in it is a shift kit, I would really like to know what small item can I add to give me power since I am low on budget?
You dont say what you budget is but the best bang for your buck will come from headers, for about 299$-499$ you can get set that will give you an improvment you can feel. Dont go for things like airfoils or an overpriced air filter. These things make no real gains that you will see. If your burget is small the best thing to do is look under free mods and cut out the bottom of the airbox under you filters and get an exhaust cut out pre cat for about 100$
1991 Z28 ZZ4 with LPE superram base, SLP runners, LPE 58mm T-body,Random Technology ramair,TES headers,24#svo injectors,and just about every other bolt on that there is. Just got a ZEX nitrous kit!
for about the price of headers you could install a nitrous kit...that'll kick ya in the pants when ya hit the button
later
larry
MÅN¡ÅÇ ©
88 IROC 5.7 TPI
ATI procharger D1sc 10#'s boost, edelbrock TES, complete MSD ignition, Borla cat-back, KB subframe connectors, accel 24# injectors...and a few other go fast goodies
http://maniac.megamania.com
later
larry
MÅN¡ÅÇ ©
88 IROC 5.7 TPI
N20 may be nice, but it also takes more than just the kit to get it running. You must get the proper pistons and such to go along with it. You would be better to just get the headers and cam
Buy an open element air filter, you will notice the difference when you stomp on it. Those stock air filter setups totally choke your car, also hedders with dual pipes will be a great help.............Let it breathe!!!
