Thinking about N2O
Old Sep 4, 2001 | 10:45 AM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
Thinking about N2O
Anyone run into problems using a 75-100 shot in a stock bottom ended L98 with low miles?
1988 GTA 5.7L TPI Auto
355 ci. block,TPIS ZZ-9 Camshaft, SLP Headers, Borla Cat Back, B&M Holeshot 2400 Stall Converter, 3.73 Richmond Gears
"Why ride a stang when birds can fly?"
http://www.geocities.com/thegta
Old Sep 4, 2001 | 06:03 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Take about 1-2 degrees of timing out to be safe,make sure your fuel and ignition system is in good working order and spray away. It'll handle it just fine.
Old Sep 4, 2001 | 07:35 PM
This can be done on stock pistons without causing premature wear?
Old Sep 6, 2001 | 10:06 AM
StockBastard's Avatar
It will work fine. You could even bump it up to a 150 shot provided you have enough fuel and you retard your timing by 3 degrees. Also, GET A HIGH PRESSURE IN LINE PUMP if you get a dry system. You will need it to keep your fuel pressure up around 75psi while you're spraying. I have an 89 IROC with the 350 TPI and a 100 shot of NOS. I didn't even feel it without the fuel pump.
"Why StockBastard?" you might ask. Well...
84 Berlinetta body w/custom paint.
92 front/rear bumper and ground affects.
89 IROC 350tpi engine w/lots of mods.
87 3.73 BW possi rear w/disk brakes.
86 interior w/IROC dash.
And finally, stock Vet rims from the early 70s.(same ones used on the 69ss)
ALL IN ONE CAR!!!
13.9@98.7
soon to be juicin'
hopin' for 12s
chazman
Aug 28, 2018 03:25 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
midge54
Jan 29, 2017 07:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
