Thinking of nitrous on new engine
Old Sep 5, 2001 | 12:07 AM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
My engine is not even in my car yet and I'm thinking of adding nitrous. I know I need a new tranny first, but I have some questions about N2O and my motor.
I have a fresh 355 w/ TRW forged pistons, stock rods and crank, AFR 190 heads, SuperRam intake, and LPE 219 cam, about 10.2:1 compression, and probably a max rpm of 6000. I'm hoping for 400-425 HP N/A at the crank. How much N2O can this engine take? A 150 HP shot, 200???
I also want to keep the nitrous hidden (THIS IS KEY), so what type of system would you run for max performance: fogger, 2-stage, wet, dry, etc. (no plate system since it's not hidden). What brand would you choose, and where would you put the jets?
89 IROC-To see mods go to: http://www.geocities.com/buckeyeroc
[This message has been edited by BuckeyeROC (edited September 04, 2001).]
Old Sep 5, 2001 | 03:39 AM
Omar's Avatar
The only way you will have a true hidden system would be to plumb the underside of the intake manifold. The solenoids would be mounted at the back of the engine, and you could run either a wet or dry kit with it. With your engine not in the car yet, this would be really easy to do.
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Sep 6, 2001 | 07:45 PM
yellowiroc2's Avatar
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
i have the engine out of my IROC. it's a 305 stock bottom end getting heads, cam, and headers. i plan to add nitrous sometime in the near future. should set this up now to hide the nitrous? what needs to be done? can someone explain in detail because I have NO experience with nitrous what so ever.
86 305 TPI
700R4
3:42 axle
4 wheel disc
-Summit cam .442" lift
-Summit chain/roller
-Summit tranny cooler
-WORLD S/R Torquer 305 heads
-High Volume oil pump
-Hypertech Airfoil
-SLP 1 5/8" headers
-Flowmaster 80 series c/b
-Taylor Spiro-Pro 8mm
-Bosch plat. plugs
-K&N Air filters
-Trans-Go shift kit
-Removed AIR
-160 Thermostat
-T/B coolant Bypass
soon... 125 shot
Old Sep 7, 2001 | 04:20 PM
CamuMan's Avatar
whats the duration on the summit cam your putting in. your setup is similiar to mine except i have a 5 speed.
midge54
Jan 29, 2017 07:00 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
dutch930
Sep 11, 2015 06:58 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
