Instaling Nitrus!!
Old Oct 8, 2001 | 08:37 AM
MR. JORDAN's Avatar
Instaling Nitrus!!
Well i got my kit and have a question before I instal it. My plans were to put the bottle in the rear compartment of the T/A (in the hole), and as I was eyeing up the situation, i noticed if I drill the hole for the main feed line straight down. the line will be awfully close to the exhaust. Should i run the line inside the car untill just after the wheel well, and then through the floor and along the fuel lines? Whats the best way to do it???
Old Oct 8, 2001 | 08:29 PM
JucinGTA's Avatar
I did it through my interior, following the center console.
Old Oct 9, 2001 | 09:24 PM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
Mine came out just above the gas tank heat shield. I ran it along the inside edge of the heat shield to the fuel lines I ran the car until it was hot and felt the line and it wasn't hot. So all is good. Just for added safety I might install a piece of heat shield hose on the line there.
Btw, I saw your post over on Macs board. Didn't get a chance to answer it.
Old Oct 10, 2001 | 09:24 AM
Killer-Z's Avatar
On my 91z i ran it on the pass. side of the car(inside) under the sill plate and behind the kick panel(there is a wiring bulkhead). I took my time and drilled a hole through the bulkhead(the wires were in the middle w/alot of room to the top and bottom). Took me forever, coz im a wuss and didn't want to nick a wire, but finally i got it through there and then it goes behind the fender and into the engine compartment. Later Derrick
Old Oct 10, 2001 | 09:26 AM
Killer-Z's Avatar
Oh and i forgot to tell why I did it this way 1)the nos line is protected by the elements and 2)i didn't want to drill a hole in my body...Later guys Derrick
Old Oct 10, 2001 | 05:49 PM
MR. JORDAN's Avatar
Right on guys!! Thanks for the help...
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
86IROC112
Aug 17, 2015 07:57 PM
